    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 843.5k Views 121 Watching
    • C
      CTH1963
      FWIW, there's also a version test in Fredo6_RoundCorner.rb (v3.3a):
      if Sketchup.version.to_i < 16
      that should be changed to '<= 16'...
      @Fredo FYI
      I tried installing FredoCorner v1.8b which lists the only dependency as LibFredo6 9.1b (archive legacy ver I have installed is 9.5k) but it complains that SU2017 or newer is required. The 'More Info' page says it should work for SU2016 and above...
      Cheers,
      Chris.
      • fredo6F
        fredo6
        @CTH1963
        If you run Sketchup SU2016, then you MUST use the legacy versions of my plugins.
        There are here.
        Fredo
        • G
          gridlandscape
          this plug in is always very useful. thankyou so much
          • E
            Einstein
            Hi!
            Is it possible with Report On Areas to auto-refresh calculation when selection is changed?
            • fredo6F
              fredo6
              @einstein said:
              Hi!
              The calculation of the report may take time, in seconds.
              So, an automatic recalculation on any change of a selection could be counterproductive, as you may want to select several objects in a row.
              That's why currently ReportArea just highlight the Refresh button in Red when a change of selection takes place.
              • E
                Einstein
                Still, I think this could be an option. Not a default one, but an available setting. I personally use this tool for low number of faces and with fast computer. Auto-recalculation would not be counterproductive for me. But it's just a suggestion πŸ˜„
                • fredo6F
                  fredo6
                  NEW RELEASE: FredoTools v4.0b - 06 Dec 20
                  Requirement: LibFredo6 v10.4b or above
                  FredoTools 4.0b is a minor release for ReportLabelArea, offering an option for automatic refresh of the reports.
                  See FredoTools plugin home page for Download.
                  See also main post of this thread for User Discussion.
                  Fredo
                  • fredo6F
                    fredo6
                    Here it is....
                    The option is in the Default Parameters.
                    Fredo
                    • E
                      Einstein
                      @fredo6 said:
                      Here it is....
                      Fredo
                      Thank you reeely much! You are fantastic πŸ˜„
                      • K
                        kenteichmann
                        I just downloaded Fredotools-v4.ob-06Dec20 to be used with Sketchup Pro 2021. I have the latest Windows 10 PC. I open the Fredotools download and I get this message. "This does not appear to be a Sketch model." I get the message with Sketchup 2021 open and unopened. DOES Fredotools-v4.ob WORK IN 2021 SKETCHUP?
                          You don't open extensions in SketchUp with File>Open. Instead, go to the Window menu, click on Extension Manager and then the Install Extension button. Navigate to where you saved the extension file, select it, and choose Open. Also make sure you download and install the LibFredo6 file as well.
                          Better would be to go to Resources at the top of this page and download the Sketchucation Plugin Store tool. Install that as above and then use it to search for and install Fredo6's extensions and others. If you do that the installation is automatically done correctly and you'll be able to see when there are updates to extensions.
                          And yes, Fredotools works just fine in SketchUp 2021.
                          • fredo6F
                            fredo6
                            NEW RELEASE: FredoTools v4.1a - 24 Apr 21
                            FredoTools 4.1a is a technical release for performance of selection contextual menu.
                            Fredo
                            • K
                              kakashi66
                              I love FredoTools, especially Thru Paint. I have come across an issue that may be know or not. I didn't feel like going through 14 pages to see.
                              I noticed that when using TP, if you shift to pan the tool changes to the picker tool not the paint tool. If I shift pan again it goes back to the paint tool. Is this something that can be fixed?
                              SU pro 2020
                              FredoTools 4.1a
                              LibFredo6 11.8a
                              • fredo6F
                                fredo6
                                Thanks for catching this problem. Definitely a bug which needs to be fixed.
                                • O
                                  oheimala
                                  Hi. The "Solid volume" is very useful in my job, thanks a lot! A great add to it would be a mass calculator. Just an input for material density and the solid mass would be seen; or a even better if a tiny sheet to save some own densities. I have not found any plugins for easy mass reporting. Cheers!
                                  • C
                                    cadmunkey
                                    "SUSolid.com" plugin works great for weights. You can input any materials you like.
                                    • T
                                      tcn_ozgr
                                      hello fredo we are a smal company and ve use fredo tools in our job,
                                      thank u for this amazing addon,
                                      we want an extra feature in fredo tool for that we try to contact with you.
                                      pls contact with us.
                                      • fredo6F
                                        fredo6
                                        NEW RELEASE: FredoTools v4.1b - 10 Jul 21
                                        FredoTools 4.1b fixes major bugs in ColorByAltitude (min-max boundaries, wrong coloring on Mac)
                                        Fredo
                                        • T
                                          tcn_ozgr
                                          what I mean is we want to export the information of the model drawn in sketchup as .peb,
                                          Is this possible or should a new plugin be written?
                                          We have the necessary protocol information and details.
                                          We hope you can help us with this situation, if a new plugin needs to be written we would like to hire you or if you have any other way of working and plans we would like to hear from you.
                                          • C
                                            ct103stu0
                                            Installed newest LibFredo6, then FredoTools v4.1b and to this error:
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
