    Signature question
    22 Posts 8 Posters 1.2k Views 8 Watching
    • sdmitchS Offline
      sdmitch
      This is a SketchUcation question but I couldn't find an option for that. I have been using and attaching a signature for months but recently I unchecked the include signature option for a post. I later re-checked the option but the signature was not attached to subsequent post. I went to User Control Panel and attempted to Edit Signature but now it tells me that I am not authorized to use a signature. What can I do to fix this problem.
      http://sdmitch.blogspot.com/
        Edit your post and see at the bottom to attach your signature (I did it for this post of yours - all seems to be working fine).
        • sdmitchS Offline
          sdmitch
          The option was checked when I asked the question but the signature hasn't been included.
          The option doesn't stay selected. I am in edit mode now and have checked the option again.
            Well, I do not know why it is happening... When I checked it, it added the signature automatically. Sorry, I am stumped.
            This is where you could set to attach your signature by default but as far as I can tell, it is set "yes" for you.
            http://forums.sketchucation.com/ucp.php?i=prefs&mode=post
              It's probably a cookie thing. Delete your cookies and return to the SCF site to set the signature option.
                There's also a 100 character limit
                • sdmitchS Offline
                  sdmitch
                  Gaieus, That makes two of us. I had been to all those places as well. I logged out and logged back in thinking that might reset things but no. I changed my password just for the fun of it, didn't help.
                  Dave, I deleted all the board cookies twice, nada.
                  Rich, The signature is the same as it has always been. I can't change it because I'm 'not autorised'
                  Maybe it will mysteriously get its' mind right at some point but, if you should happen to think of anything else I could try, please let me know.
                  ps. Attach a signature is checked.
                    Very strange. I can't see anything that says you aren't authorized to add a signature and everything seems to be set up to display it. ❓
                      Try now.
                      • sdmitchS Offline
                        sdmitch
                        testing 123
                        • TIGT Online
                          It's there !
                            Yeah. I don't know what he's talking about! 😆
                            • sdmitchS Offline
                              sdmitch
                              You fixed it!!!!!!!!!!!!!
                              • irwanwrI Offline
                                irwanwr
                                i can see that Gaieus signature is now a bit shorter than usual
                                • bmikeB Offline
                                  bmike
                                  so, having the same issue. i cannot create a signature. deleted the board cookies, with no luck.
                                  any help?
                                  -mike
                                  mike beganyi design + consulting llc
                                    Weird. I just added one to mine and at least I can see it.
                                    • mitcorbM Offline
                                      mitcorb
                                      I posted this recently: http://forums.sketchucation.com/viewtopic.php?f=76&t=42160#p373845
                                      Edit: And I just checked in Edit Signature and got this: "You are not authorised to define a signature."
                                      • bmikeB Offline
                                        bmike
                                        That is what I get.
                                        • mitcorbM Offline
                                          mitcorb
                                          It appears that some kind of Forum permission setting got scrambled, apparently random, probably sunspots.
                                          • mitcorbM Offline
                                            mitcorb
                                            I just happened to be viewing the Plugins Index and noticed that my signature showed up at this location: http://forums.sketchucation.com/viewtopic.php?t=24826#p336716
                                            However, at the moment of this writing, I cannot say that clicking on the above link will show the signature.
                                            Well, it did show up. So, why does it not show up otherwise?
                                            • 1 / 2
