    Constructive Rendering Criticism
    renderpluginsextensions
    23 Posts 7 Posters 2.1k Views 7 Watching
      JM2
      Hey everyone...
      I'm doing some simple renderings for an architect I work for, and I wanted to see if I could get some constructive criticism on the quality, technique, etc. I've only been rendering for about a year and I really want to expand my knowledge and skills in this area. I've attached an example of my work for people to comment on.
      Programs:
      Sketchup 7
      Vray 1.49
      Photoshop CS5
      I appreciate advice that can be given.
      Thanks.
      Project for the architect
      • peter_shawP Offline
        peter_shaw
        looks good! really like the rusty look.
        some criticism: the textures in the foreground (especially the white pebbles) and the shadows of the tree look a little off. i guess they have been done in post pro? i think u can do the whole scene minus the sky via modelling. also try "make fur" for the grass patches, really good and quick results.
        my approach in general would be to make as much as possible via rendering, because my post pro skills aren't that good. but i guess thats a matter of personal taste and style
          JM2
          Thanks for the crits! I do in fact add most of my textures in post production, but I'm currently trying to figure out ways to do more in the actual rendering process, without having to resort to 3ds Max, if at all possible.
            peter_shaw
            why not, you do have vray after all. a very good renderer, albeit the learning curve is a bit steep. but once u got the basics, it's easier and less "messy" than post pro IMO.
            • Chris FullmerC Offline
              Here are some thoughts:
              • The grass looks very flat. If you are adding detail in post-pro, try painting in some grass in ey places to make it stand out in front of objects. In other words, grass is not flat on top, but anywhere there is an object behind the grass, the top of the grass is flat, but it should be spikey.
              • I can't tell what the white face is. I'm guessing its a wall. You might consider using a less-white white, and put a bump texture on it of some sort. Unless you really were going for a very flat bright white.
              • I don't love the 80% transparent trees. They feel flat as well, and not very vibrant. I'm a landscape guy though, so I like to see the trees happy. But I also fade mine back form time to time when necessary.
              • The tree shadow on the ground is very hard. I'm guessing you added it in post-pro. Try applying a gaussian blur filter to it. If you want to get fancy, make it more blurry the further away from the trunk it gets.
              • Is that corrugated metal on the left? If so, it feels like it could be more reflective. I would guess the bright rust color maybe should influence the color of that wall.
              • Back to grass - little tufts of grass coming up through the pavers might be nice.
              • The grass in front of the rust building looks like it has a grey edge in front of it. Not sure if that is a metal header/divider, or something. But I'd rather see it be a dark green I think.
              • The foreground is very bright. Consider darkening a bit, and there should be a gradient across it. Make it lightly darker near other objects, like the grass and pavers.
              • The reflection on the window does not feel realistic. Seems to be too black and white. I would imaging it should have more color to it, especially in the sky.
              • The model might need more detail in it. That box is very boxy.
              • I think the sky is nice and pleasant, and the general ambient color of the model rendering works well with the sky image you used. Thats good.
              πŸ˜„ well, there you go. Hopefully that is helpful. good luck!
              Chris
              All my Plugins I've written
                JM2
                @Chris:
                Thanks for all your comments! I'm still pretty new to the world of rendering so every bit of advice is appreciated.
                  Roger
                  The tree shadow is moving in a different direction than the cube shadow. The sun is 93 million miles away so rays from teh sun should be virtually parallel. This leads me that you have inserted a light in the scene rather than using "set sun as light source."
                  http://www.azcreative.com
                    Roger
                    The gray window is very confusing. Is it a window? If I am looking through it, I should see some hint of what is in teh building, not what seems to be a Southwestern scene. If it is a reflection from the outside, It should show elements of the courtyard. And, in any case, the scene would have some color in it, it would never be neutral gray.
                    Also, the top of the white fence is spikey, but its shadow is not spikey.
                    The white building in the background does not read properly. The end of the building is shown side on as a straight line. That should not happen if the white building is parallel to the red one. And even if that was a true perspective, you should move the camera as the result of that angle is visually ambiguous.
                      JM2
                      The tree shadow was actually added in post pro in Photoshop. I didn't even catch that I hadn't matched shadow angles correctly πŸ˜’
                        JM2
                        The purpose of the image on the window was to reflect the projector that will be installed inside the steel box which will show images on the window.
                        Copy that on the white building. It actually isn't parallel to the rust building which is why it looks awkward. I will have to address that problem I guess.
                        Thanks for your crits.
                        • V Offline
                          valerostudio
                          I will keep my comments to the image itself and not the technical and texture stuff because that seems to have been covered already. In creating a successful image you must think about your composition. Firstly, the proportion of your image. It seems that you are just using whatever size comes out of SU. Take advantage of the crop tool. Use a proportion that works for the image, something more horizontal like 1:1.618 (golden mean) and think about how that image lays out using the rule of thirds. Place foreground trees in a way that they peek out from the corners of the image and cast a shadow in front of you and not back towards you. Unless a client wants to specifically see the exact shadows I almost always cheat them so I can get the best looking lighting and not neccessarily the correct condition. Your shadows are part of our composition, think about them carefully. Here are some great articles on compositioning http://photoinf.com/Golden_Mean/. This is the absolute #1 thing to learn before texturing and lighting when it comes to rendering. You are afterall taking a virtual photograph.
                            Roger
                            If the image is being projected outward you would see a shadow on the screen from the protruding shade. The part of the image in the shade would would show at close to full value and the projected image in the sun struck part of the screen would be faded or even impossible to see. The person on the screen is a visually ambiguous. Maybe he is part of the protected image, maybe he is standing in the cube in front of the projector or perhaps he is a shadow on the outside cast by a person we don't see.
                            Don't be afraid to search the net for visual references or take the time to create crude models as a way of making a reality check before rendering via post processing.
                            Some render artists you conventions for things like glass when they don't really understand a setting or are to lazy to build a complete model. However, a couple of angled parallel lines across a glass surface are usually the sign of a lesser artist. The key is a lifetime of accurate observation.
                              JM2
                              Thought I would post an updated rendering of the original image I posted. Still adding the finishing touches in PS, but overall I'm really happy with the results. Thanks to everyone for their advice πŸ˜„
                              • V Offline
                                valerostudio
                                nice work!
                                • andybotA Offline
                                  andybot
                                  much better πŸ‘
                                  Are you adding trees back in post-pro?
                                    JM2
                                    @andybot said:
                                    much better πŸ‘
                                    Here are the two final renderings I did for the architect. We are actually going to show the client the black and white one but I thought the color looked good as well. I'm working on a second daytime rendering as well as a night rendering. I will post those within the next week. Thanks again for the tips!
                                    • BoxB Offline
                                      Looks nice, but I must say I'm a little confused by the Reflection or Image, it doesn't seem to reflect the correct subject if it is a reflection and it has colour in the black and white.
                                        JM2
                                        I was farther along than I thought I was, so here's the night rendering. I'm not as happy with this one, but for being my first one, I was still pleased.
                                          JM2
                                          I haven't done any post-pro work on it yet, but here's the other view of the project.
                                            JM2
                                            I know it is a little confusing...the window will serve both for viewing and light, as well as a projection screen for art.
                                            • 1 / 2
