    How can i fip faces(inverted normals)?
    4 Posts 4 Posters 12.1k Views 4 Watching
    • W Offline
      windbladezero
      thats it, how can i do it in sketchup, the model its fine, and when i import it to dae, remains fine, but when i import it again to stl(sketchup doesnt have an stl exporter integrated and the plugin i found, doesnt work, so i downloaded a program that exports from dae to stl)
      but the stl get a message error about the inverted normals and the model ends with "empty output", and i really need it
      but i dont know how to invert/flip the faces/normals
        Roger
        Select the inverted faces and right click. Then click on "Reverse Faces."
        http://www.azcreative.com
        • dukejazzD Offline
          dukejazz
          [plugin] Vbfr.rb
          by D. Bur
          Sections: Edit ; Materials - Rendering
          Three automatic tools to quickly orient/invert faces if they are not "pointing" in the correct direction("blue syndrom")
            View your model in a Style with a distinctly colored back-face-material - say bright-blue.
            Now view your model in Monochrome mode and any reversed faces will stand out.
            As has been said select them and right-click context-menu Reverse-Face to flip them.
            There are also many scripts available to flip such faces from simple flippers to swapping over front/back materials as well.
            If the face forms part of a 'solid' [probably required in the export you are doing] then selecting one correctly oriented face and using the context-menu Orient-Faces will flip all of the connected faces to be the same orientation - however if it's not solid you can get odd results as three faces on one edge can never be oriented consistently - one will also be 'wrong' !
