    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 94.9k Views 37 Watching
    • utilerU Offline
      utiler
      dex, when I open SU after loading SketchUpBIM 1.5 the units are still imperial..... how do I change them to metric?
      Just Curious...
        d_e_x
        Utiler, You can enter units along with input values. The default values are the same as those selected on the SketchUp File Template.
        In the below example, the units are in 'feet'. However, the same input can be done as "5@200mm" or "5@0.2m" or "5@20cm" if you need to use metric units.
        If the entire file should use metric, then simply, use the Metric Template while creating the SketchUp file, and SketchUpBIM will automatically switch all its input values to metric units.
        Also watch the Advanced Tutorial at http://www.sketchupbim.com/tutorials.html to understand the implementation and usage of Units.
        • PixeroP Offline
          Pixero
          I've found that if I click on "layer 0", even when I'm not using the tools, the view is set to isometric.
          Not good. 😞
            d_e_x
            Not good. 😞
            pixero, another user has already pointed this out. We will modify the behavior of SketchUpBIM to preserve the original settings of SketchUp. If the user has set his view style to "perspective", it shall be preserved while switching layers that contain SketchUpBIM elements.
            Dex
            • utilerU Offline
              utiler
              Thanks dex, I thought if units were set in the default file the input values should 'default to those units rather than having to add the units string each time... is this possible for future releases?
              great work by the way!!
              Just Curious...
                d_e_x
                If no units are entered on the Input Dialog boxes, then SketchUpBIM will default to the pre-set units. Hence, it is not required to explicitly enter units if you want to use the same units as those set on the file template.
                thanks Andrew for all your good words! It provides our team with a lot of encouragement πŸ˜„
                • fionmacoolF Offline
                  fionmacool
                  I love the idea of this plugin- It's really great and I have been waiting for someone to produce something like this for a long time. I know I should be learning how to program SketchUp myself but I haven't had the time.
                  I recommend uninstalling the previous version of sketchupbim before installing. I had problems first time I installed the new v1.5
                  This is looking really good!
                  I wonder if anyone had thoughts about the comparison between this plugin and Revit. Here is a document I created ages ago on the topic. http://bit.ly/c6BWnE
                  Probably needs some updating now. Your suggestions are most welcome.
                  Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                    d_e_x
                    Advanced Tutorial for SketchUpBIM 1.5.
                    The implementation and usage of UNITS in SketchUpBIM is discussed in the first 3 minutes of the Tutorial.
                    [flash=853,480:uelpzvub]http://www.youtube.com/v/5IKpZFamkps[/flash:uelpzvub]
                      SUFractal
                      ATTENTION!!!!!!!
                      I've discovered a problem with this plugin/tool.
                      It conflicts with TIG's 'SectionCutFace' and Chuck Vali's Instant Roof plugins. And perhaps others as well, that I am not aware of.
                      Anyone else discovering any issues with it?
                        @sufractal said:
                        ATTENTION!!!!!!!
                        Can you describe what the conflict is? When reporting problems it is more useful the more information you give.
                          SUFractal
                          @thomthom said:
                          @sufractal said:
                          ATTENTION!!!!!!!
                          Sorry Thomthom ... I should know better.
                          When operating either tool (Instant Roof or SCF) with SU-BIM installed in plugins folder, SU immediately crashes. SU-BIM doesn't seem to be affected by anything else that I can see.
                            [Without any evidence!]
                            I suspect that it somehow, ill-advisedly, messes with the base class/methods - e.g. group.copy and similar...
                            The tool's author might confirm...
                            πŸ˜’
                              And without SketchUpBIM installed everything works fine?
                              Either that, or it could be misbehaving observers - such as modifying the model in observer events.
                                Good point TT πŸ’­
                                If it's 'watching' for say a 'group creation' - as SectionCutFace does - then it might cause it to trip up as it 'intervenes'...
                                  SUFractal
                                  Yes Thomthom ... w/o SU-BIM there do not appear to be any issues with other plugins or SU at all (from what I've experienced).
                                    d_e_x
                                    Thanks for pointing this out. I'll look into the appended suggestions - and get this fixed asap.
                                      d_e_x
                                      SketchUpBIM, Instant Roof, and SectionCutFace put together - are working fine. I did not notice any crashes or any other issues. I have tested this on Windows 7, 64 Bits. Next, I am going to try this on the Mac. At this point, NO ISSUES HAVE BEEN FOUND.
                                      In the attached screen-shot, SketchUpBIM elements (columns, walls etc.) are working fine with a "Barn Gambrel" roof from Chuck Vali's Instant Roof and a cyan colored section cut from TIG's 'SectionCutFace'.
                                      TIG, Thomthom, could you confirm if there are any problems?
                                      Also, the SketchUpBIM plugin has been tested with SuPodium, and Ledas Driving Dimensions, and no issues have been found. If there is anything, then it might be platform specific; or is related to other softwares and/or privileges on some specific computers. (random hunch!)
                                        I haven't used SketchUpBIM myself yet. Just noticed the query from the user when I moderated the post.
                                        Does it extend of modify the core classes that comes with SketchUp? (I've written some notes on why this is unsafe: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/ )
                                        Does it make use of Observers? (I've tried to map out bugs and quirks with observers here: http://www.thomthom.net/software/sketchup/observers/)
                                        If it does make use of observers, what does it do? Does it just monitor, or does it attempt to make changes to the model? The Google developers has mentioned that modifying the model on observer events can very likely cause unforeseen issues.
                                          SUFractal
                                          [attachment=0:r3r61rfx]<!-- ia0 -->SBIM_SectionCut_InstantRoof.png<!-- ia0 -->[/attachment:r3r61rfx]
                                          d_e_x:
                                          TIG and TT suggested that I try upgrading to a newer version of SU (Version 8.0.11751) ... which I have done. That seems to solve the problem with the other plugins. πŸ˜„
                                          I'm embarrassed that I didn't think to check that first.
                                          Keep up the good work ... looking forward to using your great tool again.
                                          Thanks!
                                          • P Offline
                                            pjdorger
                                            wow looks awesome
                                            • 6
                                            • 7
                                            • 5 / 7
