    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 100.0k Views 37 Watching
      d_e_x
      @utiler said:
      Thanks dex, I thought if units were set in the default file the input values should 'default to those units rather than having to add the units string each time... is this possible for future releases?
      great work by the way!!
      If no units are entered on the Input Dialog boxes, then SketchUpBIM will default to the pre-set units. Hence, it is not required to explicitly enter units if you want to use the same units as those set on the file template.
      thanks Andrew for all your good words! It provides our team with a lot of encouragement πŸ˜„
      • fionmacoolF Offline
        fionmacool
        I love the idea of this plugin- It's really great and I have been waiting for someone to produce something like this for a long time. I know I should be learning how to program SketchUp myself but I haven't had the time.
        I recommend uninstalling the previous version of sketchupbim before installing. I had problems first time I installed the new v1.5
        This is looking really good!
        I wonder if anyone had thoughts about the comparison between this plugin and Revit. Here is a document I created ages ago on the topic. http://bit.ly/c6BWnE
        Probably needs some updating now. Your suggestions are most welcome.
        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
          d_e_x
          Advanced Tutorial for SketchUpBIM 1.5.
          The implementation and usage of UNITS in SketchUpBIM is discussed in the first 3 minutes of the Tutorial.
          [flash=853,480:uelpzvub]http://www.youtube.com/v/5IKpZFamkps[/flash:uelpzvub]
            SUFractal
            ATTENTION!!!!!!!
            I've discovered a problem with this plugin/tool.
            It conflicts with TIG's 'SectionCutFace' and Chuck Vali's Instant Roof plugins. And perhaps others as well, that I am not aware of.
            Anyone else discovering any issues with it?
              @sufractal said:
              ATTENTION!!!!!!!
              Can you describe what the conflict is? When reporting problems it is more useful the more information you give.
                SUFractal
                @thomthom said:
                @sufractal said:
                ATTENTION!!!!!!!
                Sorry Thomthom ... I should know better.
                When operating either tool (Instant Roof or SCF) with SU-BIM installed in plugins folder, SU immediately crashes. SU-BIM doesn't seem to be affected by anything else that I can see.
                  [Without any evidence!]
                  I suspect that it somehow, ill-advisedly, messes with the base class/methods - e.g. group.copy and similar...
                  The tool's author might confirm...
                  πŸ˜’
                    And without SketchUpBIM installed everything works fine?
                    Either that, or it could be misbehaving observers - such as modifying the model in observer events.
                      Good point TT πŸ’­
                      If it's 'watching' for say a 'group creation' - as SectionCutFace does - then it might cause it to trip up as it 'intervenes'...
                        SUFractal
                        Yes Thomthom ... w/o SU-BIM there do not appear to be any issues with other plugins or SU at all (from what I've experienced).
                          d_e_x
                          Thanks for pointing this out. I'll look into the appended suggestions - and get this fixed asap.
                            d_e_x
                            SketchUpBIM, Instant Roof, and SectionCutFace put together - are working fine. I did not notice any crashes or any other issues. I have tested this on Windows 7, 64 Bits. Next, I am going to try this on the Mac. At this point, NO ISSUES HAVE BEEN FOUND.
                            In the attached screen-shot, SketchUpBIM elements (columns, walls etc.) are working fine with a "Barn Gambrel" roof from Chuck Vali's Instant Roof and a cyan colored section cut from TIG's 'SectionCutFace'.
                            TIG, Thomthom, could you confirm if there are any problems?
                            Also, the SketchUpBIM plugin has been tested with SuPodium, and Ledas Driving Dimensions, and no issues have been found. If there is anything, then it might be platform specific; or is related to other softwares and/or privileges on some specific computers. (random hunch!)
                              I haven't used SketchUpBIM myself yet. Just noticed the query from the user when I moderated the post.
                              Does it extend of modify the core classes that comes with SketchUp? (I've written some notes on why this is unsafe: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/ )
                              Does it make use of Observers? (I've tried to map out bugs and quirks with observers here: http://www.thomthom.net/software/sketchup/observers/)
                              If it does make use of observers, what does it do? Does it just monitor, or does it attempt to make changes to the model? The Google developers has mentioned that modifying the model on observer events can very likely cause unforeseen issues.
                                SUFractal
                                [attachment=0:r3r61rfx]<!-- ia0 -->SBIM_SectionCut_InstantRoof.png<!-- ia0 -->[/attachment:r3r61rfx]
                                d_e_x:
                                TIG and TT suggested that I try upgrading to a newer version of SU (Version 8.0.11751) ... which I have done. That seems to solve the problem with the other plugins. πŸ˜„
                                I'm embarrassed that I didn't think to check that first.
                                Keep up the good work ... looking forward to using your great tool again.
                                  pjdorger
                                  wow looks awesome
                                    d_e_x
                                    Hi All,
                                    The appended blog talks about the common support issues related to the installation and first-use of SketchUpBIM.
                                    http://sketchupbim.blogspot.in/
                                    Hope it helps the community πŸ˜„
                                    Dex
                                    • brookefoxB Offline
                                      brookefox
                                      Thank you, d_e_x, for sharing this set of integrated tools.
                                      Any plans for wall intersection corner clean-up?
                                      ~ Brooke
                                      • E Offline
                                        eccowboy
                                        I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
                                        I'm working in pro7, does this plugin only work with Pro8.
                                        Thanks....
                                          brookefox
                                          You checked the install and can verify that the plug and the folder are in the plug directory?
                                          ~ Brooke
                                            Assuming you do have the files/subfolder+files properly in Plugins [and not some 'compatibility files' location because you don't have 'full' properties>security-permissions to the destination folder]...
                                            then have you checked to see if it's an Extension that needs a one time activation from Menu > Window > Preferences > Extensions, and if so perhaps a one time activation of its Toolbar from Menu > View > Toolbars ?
                                            If none of this works... have you tried using the tool's own web site? where they have a support page and tutorial pages, or even try a PM to the author here...
                                            • 5 / 7
