    Limit vray usage of cores
    renderpluginsextensions
    6 Posts 3 Posters 5.0k Views 3 Watching
    • peter_shawP Offline
      peter_shaw
      Hello everyone,
      I'm using a 4 core CPU. What has been bugging me lateley is the poor responsiveness of SU whilst rendering with vray. maxwell f.ex. has the option to limit the cores it uses.
      i didnt find an option like that in vray, but maybe there's a workaround? ❓
      edit: vray thread priority is already on lowest, doesn't do enough.
        No such option.
        Send a feature request to ChaosGroup.
        • Z Offline
          zapwizard
          I don't use V-Ray, however once your render starts you should be able to change the affinity of the V-Ray thread in the task manager.
          Press CTRL+Shift+ESC to bring up the task manager.
          Right click on the task and select "Set Affinity" then de-select some of the CPU cores.
            peter_shaw
            the problem is that vray doesn't use a seperate thread. it seems to run inside the SU thread. so limiting the cores via affinity limits SU cores as well 😞
              SU uses only 1 core at any time - so that should not be an issue.
                peter_shaw
                i meant that SU and the vray renderer use the same thread ID. so the windows method of limiting cores won't do anything, if i want more perfomance for modeling in SU while rendering.
                f.ex: i set max cores to 3 of 4 for the SU cpu thread -> vray uses all 3 cores, SU can't use any.
