    SketchUp 8 M2 is out!
    157 Posts 49 Posters 40.2k Views 49 Watching
    • soloS Offline
      solo
      @hellnbak said:
      Sounds great, but I think I'll wait until any bugs show up and get fixed. Same way with Windows updates, occasionally they cause more problems than they solve.
      The bugs are fixed, that's why it was in beta, so no probs it's good to go.
      http://www.solos-art.com
      • jbacusJ Offline
        jbacus
        @swedishnitro said:
        I personally believe architecture schools across the world should be teaching SU to students by week 2.
        A surprisingly large number of them already are 😉
        john
        "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
        John Bacus
        jbacus@sketchup.com
        • hellnbakH Offline
          hellnbak
          Well, I'll trust your judgement and go for it, but only because it's you 😉
            driven
            not to rain on the parade, but any other Mac users seeing 'grayed out' inoperable Toolbars.
            Some Google, and all others. it seems.
            I was using them at the time and went to switch tools...
            curious
            never seen this one before tonight.
            I did install Maxwell Render today, but it's not active...
            • mitcorbM Offline
              mitcorb
              To me, what you've done in M2 is great, especially the plugin/extension improvements for both users and authors.
              • jeff hammondJ Offline
                jeff hammond
                i can now open supro on different computers and they both run without one being [EXPIRED]
                probably something to do with the pro trial not reverting to free now..
                uh.. ok.. maybe i wasn't connected to the same network or something when i had two sketchups open earlier because now when i try it, i CAN NOT even use sketchup on a different computer..
                previously, if you tried this, only one would be pro and the rest would be [expired]pro (i.e.-free version)
                now, i can only have sketchup open on one computer at a time ?? unless i install both free and pro on all computers??
                this kinda sucks.
                [EDIT] --
                this kinda sucks.
                well, i guess it isn't too bad.. i just have to turn off wifi prior to launching on a second computer..
                i mean, it's not like i'm trying to be shiesty or anything.. i just can't sit at one computer all day long and draw..
                i'll often have project files in my dropbox so i can pick up a laptop and lay on the floor while drawing for a while.. take the computer outside with me.. etc..
                and i'm not going to buy another license for that privilege 😄
                [or is that what i'm supposed to do? like legally, what's the verdict on that?]
                dotdotdot
                  Nay, I have this version installed on my desktop and laptop at the same time and have never had any issues with running either. Both connected to the net (lappy via wifi but the same router as the desktop).
                  True however that my wife has occupied my laptop so I have little chance to break SU on it. 😒
                    jeff hammond
                    here's what i get when i try to launch on another computer:
                    [and my only choice at this point is to close sketchup.. i.e.- i can't use it]
                    dotdotdot
                      jeff hammond
                      they probably aren't on the same network then.. for instance, can you use one for a render slave under the configuration you're using? or browse and transfer files between the two computers?
                      dotdotdot
                        It must be the same network. The wifi is coming from my router.
                        I don't know, what's going on there, Jeff. But please, post either here in the bug reports forum or over the Google forums as you are also active there. I will make sure it is noticed but certainly Googlers are also monitoring these places in the coming days.
                          jeff hammond
                          well, JB is in this thread already 😉
                          dotdotdot
                            jeff hammond
                            I don't know all the techno mumbo jumbo but they aren't on the same LAN or else you wouldnt be able to have two computers running pro under the same license at any given time (unless you launched one while off the network)
                            [edit] or maybe the license check is being done via google and not a LAN.. dunno really but I doubt it.
                            I'm pretty sure you've always been allowed to use a pro license on multiple computers ,but, you could only use the license on one computer at a time.
                            previously, if you launched SU on a second computer and it saw that your license was already being used, it would open as SU free instead of pro. it's been like that for as long as I can remember..
                            my gripe now is that since supro and free are totally different installs, I can no longer launch suFree on a second computer unless I have both pro and free installed (I need pro installed on all the computers.. putting the free version on them as well just seems silly.. especially when trying to keep everything synced up between the two separate apps and separate computers)
                            dotdotdot
                              jeff hammond
                              oh.. so this same situation is being discussed at the blog as well..
                              Error 400 (Bad Request)!!1
                              (www.blogger.com)
                              i guess i'll wait on official word til i decide what i'm going to do but for now, i'm just going to have to block connections via my firewall.. 😒
                              dotdotdot
                                jeff hammond
                                [so i guess since i've made so many posts in a row so far, another one isn't going to hurt]
                                L o L..
                                so out of curiosity, i downloaded su8 free and installed it.. guess what happened.
                                it overwrote my su8 pro install.. no warning - nothing.. just wiped out the pro version..
                                so apparently, i can't even do what i was considering earlier which is to have both a pro and free version installed so i can use two sketchups while on the same network…
                                @John,
                                seriously, i respect what you and your team do.. i like your vision of the future of sketchup and trust you at the helm.. but this is definitely a blunder
                                dotdotdot
                                • Chris FullmerC Offline
                                  They might have underestimated how many of us have SketchUp installed on multiple machines on the same network and occasionally have it open on more than machine.
                                  I'm guessing it works the same way on network licenses? We've got quite a few network licenses at work, but sometimes there are more of us using it than we have licenses for, and it just reverts to the trial. Looks like that won't be the case anymore? It doesn't happen too often for me, but occasionally.
                                  What I do get more often than not is my IT team messes up my server license location and I go for a few months not being able to access the license server until they can find time to straighten it out for me. Now though, I'll be stuck unable to open SU? I'll have to do some testing on this.
                                  All my Plugins I've written
                                  • halroachH Offline
                                    halroach
                                    Advanced Camera Tools are now installed by default, so they no longer require a separate plugin
                                    I hope this will retain the ability to still use the old "film & stage" plugin which works so much better.
                                    I mostly use film and stage to create cameras for scene position information, and for copying cameras between models for easy scene transferring.
                                    I actually tried out the "Advanced Camera Tools" plugin when it first came out and it kept messing up my scenes every time I wanted to create, move, remove a camera. The idea behind the advanced tools was good, but it really messed things up... maybe an option to disable automatic scene creation would have helped. I can't put my finger on what was bugging me most then, but I am sure to install M2 sometime soon, and I'll update you guys why it was so difficult to use. Has anyone else had any problems with that?
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                    • pbacotP Offline
                                      [attachment=0:3hp71n8o]<!-- ia0 -->screen 2011-12-01 at 8.30.16 PM.jpg<!-- ia0 -->[/attachment:3hp71n8o]
                                      i got it too. no network. SU crashed when I first opened it. Then I opened and got that notice. I waited a bit and opened again and OK so far.
                                      • ChiefwoodworkerC Offline
                                        Chiefwoodworker
                                        I just installed it and was really disappointed that the Print functionality is still broken. The biggest problem is in printing to scale. For some reason SketchUp insists on printing white space. Unless you minimize the white space in the window it will print on multiple wasted pages. In addition, if you are using metric mm in the scale side it sometimes, though not always, insists on changing the scale to suit inches. For example, if I enter 1 mm for "In the printout" and 100 mm for "In SketchUp" everything is fine until I change focus away from the Print Preview dialog box at which time 1 is changed to 25.4 and 100 is changed to 2542.2. The 25.4 obviously represents 25.4 mm in 1". The 2542.2 is supposed to represent 2540 mm in 100", but where the extra 2.2 mm come from who knows. Multiplying 25.4 by 100 shouldn't be too hard for SketchUp. Still, the biggest problem is SketchUp's insistence on printing white space. Why it can't calculate a bounding box for the objects in the window and use that is a mystery to me. But this problem plagues every new user to SketchUp and it has been there since day 1. Will it ever get fixed?
                                        That said, I am a huge SketchUp fan.
                                        Joe....
                                        http://www.srww.com
                                          jeff hammond
                                          hey chief.. you have suPro so maybe save some headaches and do your printing via layout?
                                          dotdotdot
                                          • KrisidiousK Offline
                                            Krisidious
                                            great time to install fresh and start over with a blank plugin folder.
                                            By: Kristoff Rand
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
