    SketchUp 8 M2 is out!
    157 Posts 49 Posters 40.4k Views 49 Watching
    • jeff hammondJ Offline
      @gaieus said:
      Nay, I have this version installed on my desktop and laptop at the same time and have never had any issues with running either. Both connected to the net (lappy via wifi but the same router as the desktop).
      they probably aren't on the same network then.. for instance, can you use one for a render slave under the configuration you're using? or browse and transfer files between the two computers?
        It must be the same network. The wifi is coming from my router.
        I don't know, what's going on there, Jeff. But please, post either here in the bug reports forum or over the Google forums as you are also active there. I will make sure it is noticed but certainly Googlers are also monitoring these places in the coming days.
          well, JB is in this thread already 😉
            I don't know all the techno mumbo jumbo but they aren't on the same LAN or else you wouldnt be able to have two computers running pro under the same license at any given time (unless you launched one while off the network)
            [edit] or maybe the license check is being done via google and not a LAN.. dunno really but I doubt it.
            I'm pretty sure you've always been allowed to use a pro license on multiple computers ,but, you could only use the license on one computer at a time.
            previously, if you launched SU on a second computer and it saw that your license was already being used, it would open as SU free instead of pro. it's been like that for as long as I can remember..
            my gripe now is that since supro and free are totally different installs, I can no longer launch suFree on a second computer unless I have both pro and free installed (I need pro installed on all the computers.. putting the free version on them as well just seems silly.. especially when trying to keep everything synced up between the two separate apps and separate computers)
              oh.. so this same situation is being discussed at the blog as well..
              Error 400 (Bad Request)!!1
              (www.blogger.com)
              i guess i'll wait on official word til i decide what i'm going to do but for now, i'm just going to have to block connections via my firewall.. 😒
                [so i guess since i've made so many posts in a row so far, another one isn't going to hurt]
                L o L..
                so out of curiosity, i downloaded su8 free and installed it.. guess what happened.
                it overwrote my su8 pro install.. no warning - nothing.. just wiped out the pro version..
                so apparently, i can't even do what i was considering earlier which is to have both a pro and free version installed so i can use two sketchups while on the same network…
                @John,
                seriously, i respect what you and your team do.. i like your vision of the future of sketchup and trust you at the helm.. but this is definitely a blunder
                • Chris FullmerC Offline
                  They might have underestimated how many of us have SketchUp installed on multiple machines on the same network and occasionally have it open on more than machine.
                  I'm guessing it works the same way on network licenses? We've got quite a few network licenses at work, but sometimes there are more of us using it than we have licenses for, and it just reverts to the trial. Looks like that won't be the case anymore? It doesn't happen too often for me, but occasionally.
                  What I do get more often than not is my IT team messes up my server license location and I go for a few months not being able to access the license server until they can find time to straighten it out for me. Now though, I'll be stuck unable to open SU? I'll have to do some testing on this.
                  • halroachH Offline
                    halroach
                    Advanced Camera Tools are now installed by default, so they no longer require a separate plugin
                    I hope this will retain the ability to still use the old "film & stage" plugin which works so much better.
                    I mostly use film and stage to create cameras for scene position information, and for copying cameras between models for easy scene transferring.
                    I actually tried out the "Advanced Camera Tools" plugin when it first came out and it kept messing up my scenes every time I wanted to create, move, remove a camera. The idea behind the advanced tools was good, but it really messed things up... maybe an option to disable automatic scene creation would have helped. I can't put my finger on what was bugging me most then, but I am sure to install M2 sometime soon, and I'll update you guys why it was so difficult to use. Has anyone else had any problems with that?
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • pbacotP Offline
                      here's what i get when i try to launch on another computer:
                      [and my only choice at this point is to close sketchup.. i.e.- i can't use it]
                      [attachment=0:3hp71n8o]<!-- ia0 -->screen 2011-12-01 at 8.30.16 PM.jpg<!-- ia0 -->[/attachment:3hp71n8o]
                      i got it too. no network. SU crashed when I first opened it. Then I opened and got that notice. I waited a bit and opened again and OK so far.
                      • ChiefwoodworkerC Offline
                        Chiefwoodworker
                        I just installed it and was really disappointed that the Print functionality is still broken. The biggest problem is in printing to scale. For some reason SketchUp insists on printing white space. Unless you minimize the white space in the window it will print on multiple wasted pages. In addition, if you are using metric mm in the scale side it sometimes, though not always, insists on changing the scale to suit inches. For example, if I enter 1 mm for "In the printout" and 100 mm for "In SketchUp" everything is fine until I change focus away from the Print Preview dialog box at which time 1 is changed to 25.4 and 100 is changed to 2542.2. The 25.4 obviously represents 25.4 mm in 1". The 2542.2 is supposed to represent 2540 mm in 100", but where the extra 2.2 mm come from who knows. Multiplying 25.4 by 100 shouldn't be too hard for SketchUp. Still, the biggest problem is SketchUp's insistence on printing white space. Why it can't calculate a bounding box for the objects in the window and use that is a mystery to me. But this problem plagues every new user to SketchUp and it has been there since day 1. Will it ever get fixed?
                        That said, I am a huge SketchUp fan.
                        Joe....
                        http://www.srww.com
                          hey chief.. you have suPro so maybe save some headaches and do your printing via layout?
                          • KrisidiousK Offline
                            Krisidious
                            great time to install fresh and start over with a blank plugin folder.
                            By: Kristoff Rand
                            • jbacusJ Offline
                              jbacus
                              now, i can only have sketchup open on one computer at a time ?? unless i install both free and pro on all computers??
                              It sounds like you may be using a network license, not a single-user license. You'll need to change some things about your configuration to use SU8M2. Please drop us a line here for more information.
                              "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                              John Bacus
                              jbacus@sketchup.com
                              • jbacusJ Offline
                                jbacus
                                ...and I'll update you guys why it was so difficult to use. Has anyone else had any problems with that?
                                I'd be keen to hear why you prefer the old "Film & Stage" plugin to the new "Advanced Camera Tools" as well. We think the new version works better than the old one, of course 😉
                                John Bacus
                                jbacus@sketchup.com
                                • jbacusJ Offline
                                  jbacus
                                  LayOut is the better solution to this problem and it contains many tools that will help you print more effectively to scale.
                                  John Bacus
                                  jbacus@sketchup.com
                                    Krisidious
                                    did I hear someone say plugin installer?
                                    By: Kristoff Rand
                                      hmm..you know, it's been quite a while since i bought pro but you might be right re: the network license.. i actually bought 3 licenses at once (from @last) but two were for windows and the third (mine) is mac.. i always assumed mine was a single-user license since it was a different OS but my user name is "<company name> -User 3"..
                                      my su8 upgrade email says this prior to listing the SN
                                      SketchUp Pro 8 Commercial License for OSX - 1 Seats
                                      does that means i have a network license instead of single user?
                                      [fwiw, one of the licenses 'home base' is in florida, one in denver, then mine in NYC.. i haven't talked with them yet about this but i assume they're going to need sorted out as well 😉 ]
                                      but yeah, i'll mail you guys privately to get this sorted..
                                      • kenK Offline
                                        ken
                                        DAMN
                                        Well here goes a Friday wasted on this upgrade.
                                        1. After installing I now have a major grayed out context menu. Desktop, Win 7 Home Premium. Which I did not have before this upgrade. Note, don't have gray out problems with laptop, Sketchup M1, Win XP.
                                        2. Can't run on two machine at same time. Wish to run on both machines when I come back from working remote. Now I can't do that.
                                        On side note, if I have Sketchup M2 open on the desktop, and try to open Sketchup on laptop M1, it will open on the laptop, however it operates strangely, drawing a line with the pencil doesn't work right away, there is a delay in drawing the line until you select another tool.
                                        If I have Sketchup M1 open on the laptop, then try to open Sketchup M2 on the desktop, it indicates you have more than one running and will shut down.
                                        Check my license, Single-user.
                                        1. Tried to re-install older version, M1 on desktop as I have a project to get out. However I can not re-install Sketchup from an older version over a newer version.
                                        So big question, if I remove Sketchup M2 from the desktop, write down my pro license number, can I re-install the older version and use the old license number. Need to get back to work.
                                        Ken, peeved at myself for doing this install when I had work to be done.
                                        • kenK Offline
                                          ken
                                          OK, I am back to Sketchup V 8.0.481 M1. Grayed out context menu gone.
                                          Now back to work.
                                          • jbacusJ Offline
                                            jbacus
                                            I'll leave it to the Sales gang to get you sorted out officially but it looks to me like you have a single-seat network license, not a single-user license. Fill out the form I referenced above and we'll get to you as soon as we can.
                                            John Bacus
                                            jbacus@sketchup.com
                                            • 2 / 8
