    Default Material ... huh?
    10 Posts 5 Posters 514 Views 5 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      I have a question about the default material. There's the unpainted default, set in Styles. There is also a material default, which replaces a color when you unpaint it with the material browser. How do you change the color of that material default?
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • cottyC Offline
        cotty
        I dont't thinks that there is a difference between the front face color (style dialog) and the standardmaterial, because if you change the color in the styles dialog, the standard material changes, too.
        my SketchUp gallery
        • JoelM3DMJ Offline
          JoelM3DM
          Not so. I have my default face front and back set to nice blah neutrals. I paint default with the material browser and faces turn green. Bright green! I don't want green. I want blah.
            Joel, could you post an example SKP with your default material applied?
              Could it be your backside default material is green?
              • cottyC Offline
                cotty
                For me the standard material shows the colors from front- and backside like defined in the style dialog. Or what do you mean by default material?
                my SketchUp gallery
                • JoelM3DMJ Offline
                  JoelM3DM
                  I discovered something. This happens when the face is part of a group. If I paint the default material (unpaint it) then it returns to the original color of the group.
                    It's a very useful feature:
                    http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94958
                      Ah yes, group and component materials are suppressed as long as faces have their own materials. As a general rule of thumb, you should never apply materials to groups/components. This is the sign of lazineyy and will lead to confusion. πŸ˜„
                      Anyway, if you end up with lots of confusing and unnecessary group materials, you can easily get rid of them with this plugin: http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                      • JoelM3DMJ Offline
                        JoelM3DM
                        Yes, I know about painting a group and the "windshield phenomenon" (the default faces will take color and the colored faces will not), but I did not know that the group acquires its own default color. You learn something every day!
