    [Plugin] Purge Folder of SKPs
    9 Posts 5 Posters 11.4k Views 5 Watching
    • halroachH Offline
      halroach
      Would there be a way to automate the Purge command to a whole folder full of SKP models? Either with an external script or from within Sketchup...
      Ideas?
      EDIT: by TIG
      See next post in this thread ! http://forums.sketchucation.com/viewtopic.php?p=367797#p367797
      FlexTools - Super Quick Windows, Doors, Slats...
        @tig said:
        Copy/paste this code into a file called ' TIG-batchpurge.rb' in the Plugins folder
        Added the file...
        Copy/paste this code into a file called ' TIG-batchpurge.rb' in the Plugins folder EDIT: 20111126 TIG...*### Using File.expand_path() rather than .tr()
        for attempted Unicode friendliness ???*
        <span class="syntaxdefault">module TIG<br />    def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">batchpurge</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">      puts<br />      model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />      path</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">save</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      files</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">      dir</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      skps</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">      Dir</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entries</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dir</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">        next unless File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">extname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">downcase</span><span class="syntaxkeyword">==</span><span class="syntaxstring">".skp"<br /></span><span class="syntaxdefault">        skps </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dir</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">### by returning to the 1st one we ensure all get processed...<br /></span><span class="syntaxdefault">      skps</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">      skps </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> skps</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">      temp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br />      max</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">skps</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1<br />      skps</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_with_index</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">skp</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">        next if not Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">open_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">skp</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        if files</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">          t</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">files<br />          File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">          File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">t</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        end<br />       if i </span><span class="syntaxkeyword">!=</span><span class="syntaxdefault"> max<br />        puts skp<br />        files</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">        temp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dir</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"#"</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">rand</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">+</span><span class="syntaxstring">".skp"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        puts </span><span class="syntaxstring">"...Purging..."<br /></span><span class="syntaxdefault">        model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />        path</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        len</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />        puts </span><span class="syntaxstring">"Components "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">len</span><span class="syntaxkeyword">+</span><span class="syntaxstring">" >>> "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        len</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />        puts </span><span class="syntaxstring">"Layers "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">len</span><span class="syntaxkeyword">+</span><span class="syntaxstring">" >>> "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        len</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />        puts </span><span class="syntaxstring">"Materials "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">len</span><span class="syntaxkeyword">+</span><span class="syntaxstring">" >>> "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        len</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">styles</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">styles</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />        puts </span><span class="syntaxstring">"Styles "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">len</span><span class="syntaxkeyword">+</span><span class="syntaxstring">" >>> "</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">styles</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />        puts path<br />        puts </span><span class="syntaxstring">"...Saving..."<br /></span><span class="syntaxdefault">        puts model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">save</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">temp</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        puts<br />        files </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> temp </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> path<br />       end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">### tidy up - should never be needed!<br /></span><span class="syntaxdefault">      File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">temp</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">if temp and File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">temp</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">      UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br />      puts </span><span class="syntaxstring">"Done."<br /></span><span class="syntaxdefault">    end<br />end</span>
        To use open one of the SKPs in the folder to be processed.
        Type TIG.batchpurge in the Ruby Console... All of the SKPs are processed in turn and purged, a report is shown for each in the Console... Use will care - it's not 'undoable'...
        • CadFatherC Offline
          CadFather
          TIG, could you please rewrite sketchup, multithread it and make it 64 bit capable - no hurry, whenever you have 5 mins...!!
          • O Offline
            ODM
            very cool.I tested and found model.save not is supporting chinese filenames and path, such as:
            Sketchup.open_file "/Users/liuzhenyi/Desktop/中文/测试.skp"
            -> true
            model = Sketchup.active_model
            model.save "/Users/liuzhenyi/Desktop/中文/测试.skp"
            -> nil
            http://www.SketchUpBAR.com
              Some aspects of Ruby 1.8~ that ships with Sketchup fail when presented with Unicode characters in names/paths - like File... operations, which are used here to get/set file-names/paths etc etc... So that's probably it...
                I've recast the code to avoid using 'tr' BUT I fear it might still fail as it must use File.delete(), File.exist?() and File.rename() to work and these might fail with Unicode names/paths ??
                Please get the code again and retry...
                • O Offline
                  ODM
                  Still not available, the Chinese path and file name.
                  path=model.path
                  path1=File.expand_path(model.path)
                  path2=model.path.tr("\\","/")
                  path.class #-> string
                  path1.class #-> string
                  path2.class #-> string
                  path,path1 and path2, all class are string, all value are "/Users/liuzhenyi/Desktop/中文/测试.skp"
                  so,path=path1=path2.
                  {File.expand_path(model.path)} same as the original {model.path.tr("\","/") or model.path}
                  File.delete(), File.exist?() and File.rename() , I tested ,not supported chinese.
                  I use google search, found it difficult to support.
                  Thanks TIG. hope you have a good solution.
                    As I suspected the File.xxx() methods you listed require ASCII character names/paths - yours are Unicode... The methods are necessary for the tool to complete successfully, so until some future version of Sketchup ports with v1.9+ Ruby we are stumped.
                    • Z Offline
                      zerothreequarter
                      sorry to dig up an old thread... but......
                      i just tried this, and it rocks, my only request/question
                      Is it possible to do make it include subfolders?
                      Thanks for the help!
