    Help making texture seamless
    14 Posts 4 Posters 2.4k Views 4 Watching
      MrMikeEsq
      Hey
      I need to make a seamless texture from this wallpaper sample
      There isn't enough of the wallpaper there to make it true to life, but is there a way to make it still look seamless? I've been trying and failing
      thanks
      Mike
        MrMikeEsq
        I also have this now, same sample different colour, slightly more of the pattern there...I don't know if this is helpful or not to someone in the know ❓
          You have plenty of pattern repeat in the height BUT in the width there's just not enough - there's a strip of missing flowers/foliage on the side[s].
          Don't you have another pattern with a full width piece ?
          This is a tileable seamless peony-rose wallpaper - but its height AND width had repeated elements - yous doesn't 😞Capture.PNG
          • Rich O BrienR Online
            This is with Offset applied. Not great though as you're missing too much pattern.
              MrMikeEsq
              Ah I guess there just isn't enough of this pattern to do this then 😞
              Rich O'Brien - thanks for that I've saved it for future use
              For this though I'll just have to find another pattern I guess that's as similar as possible - I just wanted to try this as it's the wallpaper that will be used in real life
                MrMikeEsq
                Just thought I'd conclude this thread in a decent way πŸ˜›
                As you can see I ended up using Rich O'Brien's version of the wallpaper,
                it was only to show wardrobe size really so it doesn't matter too much that the pattern's different
                And yes I know the image sucks, it's a ~1 minute podium render and is not paid work so I wasn't too bothered πŸ˜†
                  Shall I invoice you?
                    MrMikeEsq
                    For your efforts I can offer 5 Zimbabwean Dollars.
                      Wow! imagine what this version would make... πŸ˜‰
                      • urgenU Offline
                        urgen
                        .... may be it? πŸ˜•
                        .....very bad (frequent) tiling pattern πŸ˜’
                        --pupil forever...------
                        • urgenU Offline
                          urgen
                          ....I guess it's finish...
                            The wallpaper is nice....but the shirt πŸ˜•
                            • urgenU Offline
                              urgen
                              .....yes πŸ˜’ ... maybe can draw it better, but I'm not master on painting wallpaper πŸ˜• ... it's a separate kind of creativity πŸ˜‰ ...
                                MrMikeEsq
                                That's great ❗
