Help making texture seamless
Hey
I need to make a seamless texture from this wallpaper sample
There isn't enough of the wallpaper there to make it true to life, but is there a way to make it still look seamless? I've been trying and failing
thanks
Mike
I also have this now, same sample different colour, slightly more of the pattern there...I don't know if this is helpful or not to someone in the know
You have plenty of pattern repeat in the height BUT in the width there's just not enough - there's a strip of missing flowers/foliage on the side[s].
Don't you have another pattern with a full width piece ?
This is a tileable seamless peony-rose wallpaper - but its height AND width had repeated elements - yous doesn't -
This is with Offset applied. Not great though as you're missing too much pattern.
Ah I guess there just isn't enough of this pattern to do this then
Rich O'Brien - thanks for that I've saved it for future useFor this though I'll just have to find another pattern I guess that's as similar as possible - I just wanted to try this as it's the wallpaper that will be used in real life
Just thought I'd conclude this thread in a decent way
As you can see I ended up using Rich O'Brien's version of the wallpaper,
it was only to show wardrobe size really so it doesn't matter too much that the pattern's different
And yes I know the image sucks, it's a ~1 minute podium render and is not paid work so I wasn't too bothered
Shall I invoice you?
For your efforts I can offer 5 Zimbabwean Dollars.
Wow! imagine what this version would make...
.... may be it?
.....very bad (frequent) tiling pattern
....I guess it's finish...
The wallpaper is nice....but the shirt
.....yes ... maybe can draw it better, but I'm not master on painting wallpaper ... it's a separate kind of creativity ...
That's great
