    [Plugin] Curve Maker & Taper Maker v1.3.4 - Nov 2011 Update
    7 Posts 7 Posters 11.6k Views 7 Watching
      max-cx
      This version adds a new feature to Curve Maker and fixes bugs in Taper Maker and Stock Maker. It is recommended that all users upgrade to this version.
      CurveMaker has a new feature related to drawing 3d spirals. The Height parameter for an Archimedes, Bernoulli, Fermat, Golden, Hyperbolic or Lituus spiral can be specified as a total height (by appending an 's' to the height parameter value e.g. 10"s). In that case, the spiral is drawn with a constant slope so as to achieve the specified total height along the arc length of the spiral. Note that a length unit is mandatory in the specified height value. Otherwise, something like 10s will be interpreted as a value for the Sides parameter.
      You can download the latest version from http://www.drawmetal.com/download
      Terry
      • mitcorbM Offline
        mitcorb
        Thanks to you, max-cx: These have been very useful to a multitude of folks. Your generosity is greatly appreciated.
        • massimoM Offline
          massimo Moderator
          Thank you! πŸ‘
          • V Offline
            Vicspa
            Thank you πŸ‘
              dtrarch
              Thanks +++ πŸ‘
              dtr
              • G Offline
                GUNAWAN W
                Thanks really β˜€ πŸ‘ πŸ‘
                  DavorP
                  This tool would be ideal for making cords, if only Cornu spline could work in 3D.
