    [Idea] Material swapper
    7 Posts 3 Posters 632 Views 3 Watching
    • CadFatherC
      CadFather
      following texture resizer by Aerilius (Thank you) - i finally write this idea i've always been too shy to ask.. ๐Ÿ˜ณ ๐Ÿ˜„
      the plugin i have in mind would be able to:
      1 - export all the textures to a folder X (this we can already do anyway, so it is optional)
      2 - allow browsing to a folder Y - where i have other textures
      3 - swap all the textures of the model, with the others from the folder Y - (textures would just have the same name to make it easy?)
      this way we could process the materials, or swap them with higher res ones - before rendering or printing..
      what do you think? waste of synapses?
      • mitcorbM
        mitcorb
        Hi, CadFather:
        I can see nothing wrong with this idea, especially with the justification you present. You change from a low res example texture to a final high res texture in the finished product. Kind of like Fredo6's GhostComp for components in a busy file. There may already be something like this in the Plugins Index. I did not check.
        • CadFatherC
          CadFather
          yes, in fact one could pass them through fotosketcher for example (http://www.fotosketcher.com/)
          and finish off with an arty looking model, mixed with our good old sketchy styles (here i imagine google eavesdropping..)
          • TIGT
            Try this TextureSwapper http://forums.sketchucation.com/viewtopic.php?p=365582#p365582
            • CadFatherC
              CadFather
              TIG, will you stop going faster than my neurons?? ๐Ÿ˜
              • TIGT
                I take no credit for the great idea... just for making it work ๐Ÿค“
                • CadFatherC
                  CadFather
                  well...when you have only one neuron working at each moment - every idea looks great! ๐Ÿ˜„
