    Copy + Scale?
    8 Posts 5 Posters 4.0k Views 5 Watching
    • opalO
      opal
      Is there a way to scale and copy at the same time? Say you have a sphere or box and would like to have one a little smaller on the inside that lines up perfectly with the first one.. can we do that with one command? I tried using scale with the Ctrl button.. I think I confused the program.
      • T
        tfdesign
        There may be a TIG plugin for this (he seems to have it all covered πŸ˜‰ ), but afaik, it's simply a case of doing it manually and then getting the tape measure out (or the scale tool).
        My book "Let's SketchUp!" Download from here
        • BoxB
          Simple shell will do it.
          http://forums.sketchucation.com/viewtopic.php?t=33169
          • TIGT
            In addition to the thomthom linked shell tool there's a Jim_Foltz shell tool and of course JointPushPull used inwardly [Xray mode on ?]...
            • GaieusG
              The Ctrl key is a different modification key for the Scale tool. What I do (not using plugins for simpler shapes) is to copy (Ctrl+C) then scale and then paste the original copy in place (Edit menu - but I have a shortcut set up for it: Shift+Ctrl+V since Ctrl+V would be a generic, system level paste command anyway).
              • BoxB
                Actually Tig, I linked to Jim's one.
                This is Thomthom's one http://forums.sketchucation.com/viewtopic.php?t=39308
                • opalO
                  opal
                  Thanks folks... I'll give them all a go. I'm a big ctrl c/ctrl v fan πŸ˜„
                  goes to see if she's already got those plugins and didn't know what to do with them
                  • T
                    tfdesign
                    I'm just a big SketchUp fan! πŸ˜„
