    Is an entity in a surface
    13 Posts 6 Posters 1.6k Views 6 Watching
    • Al HartA Offline
      Al Hart
      There is a model.Selection function is_surface(), which is true if the current selection is a surface.
      I am looking for a similar function to determine if a single entity - say a face - is part of a surface.
      (and/or to get an array of all entities which are in the same surface)
      Any ideas?
      Al Hart
      IRender nXt from Render Plus
        <span class="syntaxdefault">def is_part_of_surface</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> entity </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  if entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  elsif entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">any</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  else<br />    false<br />  end<br />end<br /></span>
        I'm actually about to write such a method for my own plugin. Don't have it yet, but it's just traversing all connected faces of soft edges.
        (Note that it's only the soft property that SU use in regard to what is a Surface, smooth is just used for shading.)
          <span class="syntaxdefault">def&nbsp;get_surface</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">surface&nbsp;</span><span class="syntaxkeyword">=&nbsp;{}&nbsp;</span><span class="syntaxcomment">#&nbsp;Use&nbsp;hash&nbsp;for&nbsp;speedy&nbsp;lookup<br />&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword">=&nbsp;[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">until&nbsp;stack</span><span class="syntaxkeyword">.empty?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />&nbsp;&nbsp;&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">edge&nbsp;in&nbsp;edges<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">face&nbsp;in&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;next&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface</span><span class="syntaxkeyword">[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
          • Al HartA Offline
            Al Hart
            Thanks ThomThom,
            I'll give these a try.
            Al Hart
            • artmusicstudioA Offline
              artmusicstudio
              hi,
              this seems to be an interesting approach, but
              what is returned by the method?
              is it an array of elements, i can iterate?
              i am not yet familiar with "keys" etc..... -:)
              if this gives back all entities of the "surface", how could i iterate thru it?
              when i try, i get errors,
              thanx
              stan
              @thomthom said:
              <span class="syntaxdefault">def get_surface</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  surface </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Use hash for speedy lookup<br /></span><span class="syntaxdefault">  stack </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  until stack</span><span class="syntaxkeyword">.empty?<br /></span><span class="syntaxdefault">    face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />    edges </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    for edge in edges<br />      for face in edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />        next if surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        stack </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> face<br />        surface</span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face<br />      end<br />    end<br />  end<br />  surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
                slbaumgartner
                The return is an Array of all the Faces from any surface containing the Face passed as the argument. If the Face is not in a surface, the return will be an empty array.
                  artmusicstudio
                  hello,
                  thanx a lot. yes,
                  in the mean time i renamed the array to @surface.keys and got the array back. works perfectly.
                  i have to find out, if there is a way to return this array without renaming (return xxxx ???)
                  stan
                    Where did you get @surface from?
                    • Dan RathbunD Offline
                      Dan Rathbun
                      @artmusicstudio said:
                      i am not yet familiar with " keys" etc..... -:)
                      Go to the Ruby Resources "Sticky Thread" here:
                      RUBY PROGRAMMING REFERENCES
                      Get the CHM files for whatever version Ruby your SketchUp is using.
                      SketchUp v8, 2013 and earlier uses Ruby 1.8.6
                      (some earlier version used Ruby 1.8.5 and 1.8.0, FYI)
                      THEN ... lookup the Hash#keys() method
                      I'm not here much anymore.
                        artmusicstudio
                        hi thomthom,
                        the method is
                        having a smooth mesh with any loops projected on it and intesect
                        selection of one or more surfaces by user and calling the method
                        iterating thru selected surfaces
                        iteration thru all elements within one of them
                        further operation with edges within the surface, especially the smooth ones
                        this peace of code for surface works super for me.
                        stan
                          artmusicstudio
                          hi dan, thanx,
                          next one to be studied (of still so many....). -:)
                          just to be sure of universality (ruby-versions), i run the code always in 2014 and v8 in win7, vista and xp....
                          stan
                            slbaumgartner
                            TT's snippet earlier in this post contains a couple of bugs: it will raise an exception if the
                            argument isn't a Face (or something that supports #edges), and it will find false surfaces
                            built where more than two Faces meet at a soft Edge. The below fixes these issues.
                            def get_surface( face )
                              return [] unless face.is_a?(Sketchup;;Face)
                              surface = {} # Use hash for speedy lookup
                              stack = [ face ]
                              until stack.empty?
                                face = stack.shift
                                edges = face.edges.select { |e| e.soft? && e.faces.length == 2}
                                for edge in edges
                                  for face in edge.faces
                                    next if surface.key?( face )
                                    stack << face
                                    surface[ face ] = face
                              surface.keys
                            • tt_suT Offline
                              tt_su
                              That's for that revised version! 😄
