    Is an entity in a surface
    13 Posts 6 Posters 2.0k Views 6 Watching
      <span class="syntaxdefault">def&nbsp;get_surface</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">surface&nbsp;</span><span class="syntaxkeyword">=&nbsp;{}&nbsp;</span><span class="syntaxcomment">#&nbsp;Use&nbsp;hash&nbsp;for&nbsp;speedy&nbsp;lookup<br />&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword">=&nbsp;[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">until&nbsp;stack</span><span class="syntaxkeyword">.empty?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />&nbsp;&nbsp;&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">edge&nbsp;in&nbsp;edges<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">face&nbsp;in&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;next&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface</span><span class="syntaxkeyword">[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
      • Al HartA Offline
        Al Hart
        Thanks ThomThom,
        I'll give these a try.
        Al Hart
        IRender nXt from Render Plus
        • artmusicstudioA Offline
          artmusicstudio
          hi,
          this seems to be an interesting approach, but
          what is returned by the method?
          is it an array of elements, i can iterate?
          i am not yet familiar with "keys" etc..... -:)
          if this gives back all entities of the "surface", how could i iterate thru it?
          when i try, i get errors,
          thanx
          stan
          @thomthom said:
          <span class="syntaxdefault">def get_surface</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  surface </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Use hash for speedy lookup<br /></span><span class="syntaxdefault">  stack </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  until stack</span><span class="syntaxkeyword">.empty?<br /></span><span class="syntaxdefault">    face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />    edges </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    for edge in edges<br />      for face in edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />        next if surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        stack </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> face<br />        surface</span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face<br />      end<br />    end<br />  end<br />  surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
            slbaumgartner
            The return is an Array of all the Faces from any surface containing the Face passed as the argument. If the Face is not in a surface, the return will be an empty array.
              artmusicstudio
              hello,
              thanx a lot. yes,
              in the mean time i renamed the array to @surface.keys and got the array back. works perfectly.
              i have to find out, if there is a way to return this array without renaming (return xxxx ???)
              stan
                Where did you get @surface from?
                • Dan RathbunD Offline
                  Dan Rathbun
                  @artmusicstudio said:
                  i am not yet familiar with " keys" etc..... -:)
                  Go to the Ruby Resources "Sticky Thread" here:
                  RUBY PROGRAMMING REFERENCES
                  Get the CHM files for whatever version Ruby your SketchUp is using.
                  SketchUp v8, 2013 and earlier uses Ruby 1.8.6
                  (some earlier version used Ruby 1.8.5 and 1.8.0, FYI)
                  THEN ... lookup the Hash#keys() method
                  I'm not here much anymore.
                    artmusicstudio
                    hi thomthom,
                    the method is
                    having a smooth mesh with any loops projected on it and intesect
                    selection of one or more surfaces by user and calling the method
                    iterating thru selected surfaces
                    iteration thru all elements within one of them
                    further operation with edges within the surface, especially the smooth ones
                    this peace of code for surface works super for me.
                    stan
                      artmusicstudio
                      hi dan, thanx,
                      next one to be studied (of still so many....). -:)
                      just to be sure of universality (ruby-versions), i run the code always in 2014 and v8 in win7, vista and xp....
                      stan
                        slbaumgartner
                        TT's snippet earlier in this post contains a couple of bugs: it will raise an exception if the
                        argument isn't a Face (or something that supports #edges), and it will find false surfaces
                        built where more than two Faces meet at a soft Edge. The below fixes these issues.
                        def get_surface( face )
                          return [] unless face.is_a?(Sketchup;;Face)
                          surface = {} # Use hash for speedy lookup
                          stack = [ face ]
                          until stack.empty?
                            face = stack.shift
                            edges = face.edges.select { |e| e.soft? && e.faces.length == 2}
                            for edge in edges
                              for face in edge.faces
                                next if surface.key?( face )
                                stack << face
                                surface[ face ] = face
                          surface.keys
                        • tt_suT Offline
                          tt_su
                          That's for that revised version! 😄
