    Is an entity in a surface
    13 Posts 6 Posters 2.1k Views 6 Watching
      @al hart said:
      I am looking for a similar function to determine if a single entity - say a face - is part of a surface.
      <span class="syntaxdefault">def is_part_of_surface</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> entity </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  if entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  elsif entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">any</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  else<br />    false<br />  end<br />end<br /></span>
      @al hart said:
      (and/or to get an array of all entities which are in the same surface)
      I'm actually about to write such a method for my own plugin. Don't have it yet, but it's just traversing all connected faces of soft edges.
      (Note that it's only the soft property that SU use in regard to what is a Surface, smooth is just used for shading.)
        <span class="syntaxdefault">def&nbsp;get_surface</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">surface&nbsp;</span><span class="syntaxkeyword">=&nbsp;{}&nbsp;</span><span class="syntaxcomment">#&nbsp;Use&nbsp;hash&nbsp;for&nbsp;speedy&nbsp;lookup<br />&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword">=&nbsp;[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">until&nbsp;stack</span><span class="syntaxkeyword">.empty?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />&nbsp;&nbsp;&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">edge&nbsp;in&nbsp;edges<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">face&nbsp;in&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;next&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">stack&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface</span><span class="syntaxkeyword">[&nbsp;</span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
        • Al HartA Offline
          Al Hart
          Thanks ThomThom,
          I'll give these a try.
          Al Hart
          IRender nXt from Render Plus
          • artmusicstudioA Offline
            artmusicstudio
            hi,
            this seems to be an interesting approach, but
            what is returned by the method?
            is it an array of elements, i can iterate?
            i am not yet familiar with "keys" etc..... -:)
            if this gives back all entities of the "surface", how could i iterate thru it?
            when i try, i get errors,
            thanx
            stan
            @thomthom said:
            <span class="syntaxdefault">def get_surface</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  surface </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Use hash for speedy lookup<br /></span><span class="syntaxdefault">  stack </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  until stack</span><span class="syntaxkeyword">.empty?<br /></span><span class="syntaxdefault">    face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> stack</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shift<br />    edges </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">soft</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    for edge in edges<br />      for face in edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces<br />        next if surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        stack </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> face<br />        surface</span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face<br />      end<br />    end<br />  end<br />  surface</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys<br />end<br /></span>
              slbaumgartner
              The return is an Array of all the Faces from any surface containing the Face passed as the argument. If the Face is not in a surface, the return will be an empty array.
                artmusicstudio
                hello,
                thanx a lot. yes,
                in the mean time i renamed the array to @surface.keys and got the array back. works perfectly.
                i have to find out, if there is a way to return this array without renaming (return xxxx ???)
                stan
                  Where did you get @surface from?
                  • Dan RathbunD Offline
                    Dan Rathbun
                    @artmusicstudio said:
                    i am not yet familiar with " keys" etc..... -:)
                    Go to the Ruby Resources "Sticky Thread" here:
                    RUBY PROGRAMMING REFERENCES
                    Get the CHM files for whatever version Ruby your SketchUp is using.
                    SketchUp v8, 2013 and earlier uses Ruby 1.8.6
                    (some earlier version used Ruby 1.8.5 and 1.8.0, FYI)
                    THEN ... lookup the Hash#keys() method
                    I'm not here much anymore.
                      artmusicstudio
                      hi thomthom,
                      the method is
                      having a smooth mesh with any loops projected on it and intesect
                      selection of one or more surfaces by user and calling the method
                      iterating thru selected surfaces
                      iteration thru all elements within one of them
                      further operation with edges within the surface, especially the smooth ones
                      this peace of code for surface works super for me.
                      stan
                        artmusicstudio
                        hi dan, thanx,
                        next one to be studied (of still so many....). -:)
                        just to be sure of universality (ruby-versions), i run the code always in 2014 and v8 in win7, vista and xp....
                        stan
                          slbaumgartner
                          TT's snippet earlier in this post contains a couple of bugs: it will raise an exception if the
                          argument isn't a Face (or something that supports #edges), and it will find false surfaces
                          built where more than two Faces meet at a soft Edge. The below fixes these issues.
                          def get_surface( face )
                            return [] unless face.is_a?(Sketchup;;Face)
                            surface = {} # Use hash for speedy lookup
                            stack = [ face ]
                            until stack.empty?
                              face = stack.shift
                              edges = face.edges.select { |e| e.soft? && e.faces.length == 2}
                              for edge in edges
                                for face in edge.faces
                                  next if surface.key?( face )
                                  stack << face
                                  surface[ face ] = face
                            surface.keys
                          • tt_suT Offline
                            tt_su
                            That's for that revised version! 😄
