    Creating a solid from a google earth terrain
    9 Posts 4 Posters 3.0k Views 4 Watching
    • P Offline
      Posho91
      Hi folks,
      I'm experienced with AutoCAD but new to sketchup, I want to use a slicer plugin for sketchup to cut a google earth terrain into 3mm slices which can then be sent to a laser cutter to build a real life scale model.
      The trouble is the google earth terrain is an irregular surface and the plugin needs it to be a solid.
      What is the quickest/ easiest way to create a solid volume underneath the terrain surface?
      Help much appreciated!
      Thanks.
        Click the red button Plugin Index at the top of this page.
        Search for author sdmitch
        He has a plugin terrain skirt.
        Or go here
        http://sdmitch.blogspot.com/
        And you see a video of it in action πŸ˜‰
          The GE terrain is imported in a locked state so first unlock it. then open it for editing and draw some vertical lines down and connect them with horizontal lines.
            Isn't GE non planar. There was a discussion on this before. The older solution was TIG's EEbyV then intersect a flat plane etc...
            • P Offline
              Posho91
              Thanks Rich, worked perfectly!
                The terrain may be non planar but you should still be able to draw vertical lines down from the corners to get the faces. I don't have access to 7 at the moment but that's the way I've done it in the past.
                  No problem πŸ‘
                  @Dave
                  I'm saying that the imported terrain isn't always rectangular/square even though it's selected that way. I've tried in the past to make it solid using that method but it usually fails to skin.
                  Jeff Hammond has a video on making it solid but then Sam just wrote a script that negates all that fudging around. I just wish GSU would tweak it so it skinned easily.
                    Maybe it varies from selection to selection. I don't know. Is the Google Maps import different now?
                      Indeed it's not perfectly rectangular and often one or more sides do not want to skin. You can alway intersect with some faces and then get it skin easier.
