    New to sketchup
    13 Posts 4 Posters 647 Views 4 Watching
    • H
      hurleymaker
      I am a designer and maker of arcitectural details and recently a young relative of mine suggested I should check out Sketchup. It is an amazing design tool that, though I am struggling with the learning curve I find myself using it for all my projects. Great stuff.
      • H
        hurleymaker
        Thanks for the tip. I think I have enough trouble going from cad to sketchup and back. Always trying to draw line in cad and not enter and the opposite in sketchup. Two years ago I was hand drawing everything. There is only so much an old guy wants to learn.
        • GaieusG
          Jay, I suggest that you share a work of you which you think could be made better or easier and we can advise "on the fly".
            You can try also in Nurbs domain Moment Of Inspiration,
            you will find inside the same pleasure of modeling than SKetchup! πŸ˜‰
            (A free Demo unlimited time but without save is existing )
            • H
              hurleymaker
              How and where would I do that. I could send a drawing and a photo of the finished project. Also, any advice on how to get to the fredoscale download. I really need the twist tool to get a design out to a finicky client.
              • GaieusG
                You can add attachments below the text area when posting.
                The plugin is attached at the bottom of the first port in the Fredoscale topic. Note you will need an additional library, too (linked from that post)
                • H
                  hurleymaker
                  My third drawing. Not great, but it did what I wanted it to do. Make me money.Thanks Gaieus. Looks like I can send only one attachment, So I will send two replies.
                  • H
                    hurleymaker
                    photoThis is th finished project.
                      If you go to...
                      View > Face Style > Monochrome
                      You'll see that you've alot of 'Reversed Faces' in that model. Also it would benefit from using 'Components'
                      Nice username BTW. πŸ˜‰
                      • GaieusG
                        Well, there is a (broken) plugin installed on the forums and it seems that you could add more attachments at a time but it does not work. However after "adding" the attachment, you can go on adding more - just one at a time.
                        Now that finished piece is really great. Rich is right about reversed faces and components. You have some but you could use some more.
                        • H
                          hurleymaker
                          Thanks for the complment. Before the end of June 2011 I did not know sketchup existed and did not have time to downlosd it until mid July.
                          I have gotten better at using componets and groups and layers. It is getting easier. There is just a lot to learn. It is still an amazing program for me, as I can see the things in 3d before I go to the forge and get dirty.
                          • GaieusG
                            If you make a lot of this stuff, I think these plugins will be invaluable for you:
                            http://www.drawmetal.com/
                            • H
                              hurleymaker
                              already have them. They are great.
