    V-Ray doesn't save my settings
    renderpluginsextensions
    7 Posts 5 Posters 699 Views 5 Watching
    • arail1A Offline
      arail1
      V-Ray doesn't save all my material settings. I've got a concrete floor that has a Reflection layer and a bump map but when I open the scene in the morning the Reflection layer is gone and there's nothing in the bump category. I think this is happening to several other materials also.
      Anyone have any advice about this? Thanks.
      • StinkieS Offline
        Stinkie
        If you're using the lastest version, I cannot help you. If not, this should be of help: http://forums.sketchucation.com/viewtopic.php?f=322&t=32623
          Are you using the old 1.05.30 version?
          (Please post exactly the version number of VfSU you are using when asking questions. Helps a lot when coming up with the correct answer.)
          • arail1A Offline
            arail1
            I wonder if it has to do with my opening the scene on a computer that doesn't have V-Ray. I have V-Ray on my home computer but the company that I work for doesn't have a license. So I model at work then render at home in the evening. Not sure if that's causing the screw up but it's a PIA. I have to write down all the settings and double check before I render.
            Thanks for your replies.
            • chonC Offline
              chon
              I think your explanation is the right one.
              For saving time, you can save your VRay materials (right click on material name > Save material).
              Next time you open the file, right click on VRay material name > Import material. All settings will be restored... πŸ˜‰
              SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                Contact Support - might be you're running into a bug.
                • andybotA Offline
                  andybot
                  If you are copying and pasting between SU windows or loading components, that will often mess up materials (delete all the layers except diffuse) when working in vray. That is a bug currently.
