    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 60.9k Views 18 Watching
      sdmitch
      http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
      When you grab several Google Earth Terrain patches, there is often a problem with how the images overlay each other. To help with this problem, the attached plugin, Clip or Trim Terrain Mesh, allows you to select the mesh which you want to keep and the mesh to be trimmed. Everything from the 2nd mesh that falls within the boundary of the 1st mesh is deleted thus eliminating the problem.
      In cases where smaller high resolution meshes are placed on top of larger low resolution meshes, you will often be left with vertical gaps especially in areas with significant elevation change due to the differences in the resolution of the grid and the interpolation of the surface.
      Another cause of image mis-match are the border rows and columns even when the terrain patches are of the same scale. To help with this problem, use the Trim option of Clip or Trim Terrain Mesh, to remove them from the selected mesh. Press and release the Shift Key to toggle between clipping and trimming. Hopefully now Mac compatible.
      Add Terrain Skirt, adds a skirt to the terrain mesh to give depth and definition to the mesh.
      clip or trim google earth terrain meshes
      Add skirt to terrain mesh
      http://sdmitch.blogspot.com/
        Bob James
        Super!! Thank you sdmitch 👍
          srx
          Great. Thanks Sam.
          www.saurus.rs
          • P Offline
            Panga
            Thanks for this one Sam !! 👍
              sdmitch
              John, You should press and releasethe Shift key to toggle between clip and trim. Holding down the shift key is not required or advised.
                sdmitch
                I wasn't aware of that difference with Macs since I only have windows at my disposal.
                  AcesHigh
                  great plugin! Thanks a lot!
                    Don't use VK_ALT, VK_SHIFT etc - for cross platform, use
                    CONSTRAIN_MODIFIER_KEY = Shift Key
                    CONSTRAIN_MODIFIER_MASK = Shift Key
                    COPY_MODIFIER_KEY = Menu on Mac, Ctrl on PC
                    COPY_MODIFIER_MASK = Alt on Mac, Ctrl on PC
                    ALT_MODIFIER_KEY = Command on Mac, Menu on PC
                    ALT_MODIFIER_MASK = Command on Mac, Alt on PC
                    http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/tool.html (top of this page)
                    Also - when I use these, I don't try to make Shift or Control match across platforms. Because as you can see from the constant names, the modifier key to make a copy (when you use the Move tool for instance) differ from platform to platform. So just use these to match the norm for each platform.
                      sdmitch
                      Thanks ThomThom, I'm still learning and need all the help I can get.
                        No prob! Always good to see more people writing plugins. 😄
                          driven
                          Sam,
                          re: 'Clip or Trim' on MAC,
                          I just went over it all again and on the mac using if key ==16 || 131072 #shift PC || MAC,
                          makes it work as I believe you intended. [ is it?]
                          To start in 'Trim' mode:
                          'grab' grid/s >> select the 'Clip or Trim' from plugins >> press shift key once to activate 'Trim' >> click on 'Terrain' to 'Trim' grid/s in turn.
                          To start in 'Clip' mode:
                          'grab' grid/s >> select the 'Clip or Trim' from plugins >>click on 'Terrain' to 'Clip' grid/s in turn.
                          To switch between modes from either mode, press shift key once >> click on next 'Terrain'
                          To exit 'Clip or Trim' click outside of all 'Terrain' groups.
                          This is how it work with that change, I edited my above posts avoid to blind copying of my erroneous prior comments.
                          I believe this tweak is cross platform, due to the none applicable keycode being ignored, but I don't have a PC easily at hand.
                          Sorry if any confusion [other than my own] was caused by earlier comments, but I was in and out today without the time to plod through it properly.
                          john
                            driven
                            Sam,
                            doesn't toggle on a mac, I should have pointed that out. EDIT INCORRECT you DON'T need to keep it held down
                            that's what was doing my head in I checked your code and couldn't see why it wouldn't work, so I guess it's a Mac thing...
                            john
                              driven
                              removed
                                driven
                                Love the combo tool,
                                once I got my head around it EDIT removed potentially misleading comment...
                                and I found a use for it for me as well. 3D cycle route maps...
                                anyone got an easy way of using Google Maps as the terrain texture,
                                this ones manually scaled and aligned with the 'Google Earth Snapshot' then applied as a projected texture onto the Terrain Grid.
                                Maps on Terrain
                                Google if your reading, can we have a map option? please...
                                good work Sam
                                john
                                  driven
                                  No, me neither, I had a search for mac key-codes etc,,, but I might try searching mac 'toggle' as keycode 16 seems to work.
                                  EDIT 16 on it's own dosen't work on mac [I'd left the other in, but opened a copy when checking, what I'd done... sorry]
                                    mitcorb
                                    Hi, sdmitch:
                                    Thank you for your generousity in sharing this tool.
                                    • U Offline
                                      utiler
                                      Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
                                      cheers, thanks for your fantastic work!! 👍
                                      Just Curious...
                                        sdmitch
                                        Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
                                        • U Offline
                                          utiler
                                          Ok, thanks Sam.Just on GE:
                                          I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
                                          I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
                                          I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
                                          Cheers,
                                          Just Curious...
                                            sdmitch
                                            Thers is no way to "automate" that that I am aware of.
                                            • 1 / 2
