    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 62.8k Views 18 Watching
    • Bob JamesB
      Bob James
      Super!! Thank you sdmitch 👍
      • srxS
        srx
        Great. Thanks Sam.
        www.saurus.rs
        • P
          Panga
          Thanks for this one Sam !! 👍
          • sdmitchS
            sdmitch
            John, You should press and releasethe Shift key to toggle between clip and trim. Holding down the shift key is not required or advised.
            http://sdmitch.blogspot.com/
            • sdmitchS
              sdmitch
              I wasn't aware of that difference with Macs since I only have windows at my disposal.
                AcesHigh
                great plugin! Thanks a lot!
                  Don't use VK_ALT, VK_SHIFT etc - for cross platform, use
                  CONSTRAIN_MODIFIER_KEY = Shift Key
                  CONSTRAIN_MODIFIER_MASK = Shift Key
                  COPY_MODIFIER_KEY = Menu on Mac, Ctrl on PC
                  COPY_MODIFIER_MASK = Alt on Mac, Ctrl on PC
                  ALT_MODIFIER_KEY = Command on Mac, Menu on PC
                  ALT_MODIFIER_MASK = Command on Mac, Alt on PC
                  http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/tool.html (top of this page)
                  Also - when I use these, I don't try to make Shift or Control match across platforms. Because as you can see from the constant names, the modifier key to make a copy (when you use the Move tool for instance) differ from platform to platform. So just use these to match the norm for each platform.
                  • sdmitchS
                    sdmitch
                    Thanks ThomThom, I'm still learning and need all the help I can get.
                      No prob! Always good to see more people writing plugins. 😄
                        driven
                        Sam,
                        re: 'Clip or Trim' on MAC,
                        I just went over it all again and on the mac using if key ==16 || 131072 #shift PC || MAC,
                        makes it work as I believe you intended. [ is it?]
                        To start in 'Trim' mode:
                        'grab' grid/s >> select the 'Clip or Trim' from plugins >> press shift key once to activate 'Trim' >> click on 'Terrain' to 'Trim' grid/s in turn.
                        To start in 'Clip' mode:
                        'grab' grid/s >> select the 'Clip or Trim' from plugins >>click on 'Terrain' to 'Clip' grid/s in turn.
                        To switch between modes from either mode, press shift key once >> click on next 'Terrain'
                        To exit 'Clip or Trim' click outside of all 'Terrain' groups.
                        This is how it work with that change, I edited my above posts avoid to blind copying of my erroneous prior comments.
                        I believe this tweak is cross platform, due to the none applicable keycode being ignored, but I don't have a PC easily at hand.
                        Sorry if any confusion [other than my own] was caused by earlier comments, but I was in and out today without the time to plod through it properly.
                          driven
                          Sam,
                          doesn't toggle on a mac, I should have pointed that out. EDIT INCORRECT you DON'T need to keep it held down
                          that's what was doing my head in I checked your code and couldn't see why it wouldn't work, so I guess it's a Mac thing...
                            driven
                            removed
                              driven
                              Love the combo tool,
                              once I got my head around it EDIT removed potentially misleading comment...
                              and I found a use for it for me as well. 3D cycle route maps...
                              anyone got an easy way of using Google Maps as the terrain texture,
                              this ones manually scaled and aligned with the 'Google Earth Snapshot' then applied as a projected texture onto the Terrain Grid.
                              Maps on Terrain
                              Google if your reading, can we have a map option? please...
                              good work Sam
                                driven
                                No, me neither, I had a search for mac key-codes etc,,, but I might try searching mac 'toggle' as keycode 16 seems to work.
                                EDIT 16 on it's own dosen't work on mac [I'd left the other in, but opened a copy when checking, what I'd done... sorry]
                                • mitcorbM
                                  mitcorb
                                  Hi, sdmitch:
                                  Thank you for your generousity in sharing this tool.
                                  • utilerU
                                    utiler
                                    Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
                                    cheers, thanks for your fantastic work!! 👍
                                    Just Curious...
                                    • sdmitchS
                                      sdmitch
                                      Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
                                      • utilerU
                                        utiler
                                        Ok, thanks Sam.Just on GE:
                                        I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
                                        I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
                                        I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
                                        Cheers,
                                        Just Curious...
                                        • sdmitchS
                                          sdmitch
                                          Thers is no way to "automate" that that I am aware of.
                                            dinkdesign
                                            You guys are absolute legends. You take modeling to a whole new level.
                                            I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
                                            Special thanx to Gaieus and ThomThom for their constant useful contributions.
