    Dividing combined shape: line + arc
    30 Posts 9 Posters 2.6k Views 9 Watching
    • TIGT Online
      Here's a way to 'draw it' TIG-equalsegs.PNG LINK= http://forums.sketchucation.com/viewtopic.php?p=359659#p359659
      To use type into the Ruby Console
      TIG.equalsegs
      • <enter> and in the dialog input the settings for the segment length, radius, number of straight segments and number of segments radially.
        A grouped set of lines/clines/cpoints is made at the origin - straight parts to the left and radial parts to the right; you can easily rotate or flip it as needed...
      • Wo3DanW Offline
        Wo3Dan
        @dave r said:
        ...So, is there a plugin that could take a selected arc and report the central angle?
        I don't know of such a plugin although it could be done.
        I guess even the entire division could be calculated and put into a plugin.
        My approach for such a (rare) division is based entirely on SketchUp without plugins. Rare, so probably not worth a plugin.
        1. select edge and arc (inside a group) -> read total length L -> divide value L by number of segments needed -> gives new segment length.
        2. draw a line exactly the total length L and divide into decired number of segments.
        3. use one segment and start building the shape along the (edge+arc)-group
        Rotation of subsequent segments towards the existing arc is a bit tricky but the result is quite good.
        I think it could even be better starting with an arc that has more or less the same low number of segments as the result. In other words, don't start with 12 segments if the endshape requires only 2 or three to cover the same angle.
        Does this makes sense?
        p.s. (Arc+edge) length is in fact (segments+edge) length.
        That's why the arc's number of segments shouldn't be to high but resemble the resulting situation.
        • mitcorbM Offline
          mitcorb
          The closest plugin I could find in the candy st--uh Plugins Index was "Angle Between Planes". I thought there was one called simply "Angle Between". Neither of these would seem to do what you describe. And, of course, there are a few arc centerpoint finders.
          Yeah, Dave, I was pretty much bumfuzzled at first. But I had to leave the dialog. My day job was calling. When I got back, I found the real hitters had stepped in. 💚
          • TIGT Online
            In addition to my earlier tool here's another - with this one you enter the segment length, the total angle the arc will sweep [in degrees], and the number of segments.
            It then calculates the required radius and draws the equal fixed length segments inside a group for you, starting from the origin c/clockwise and marking points etc...Capture.PNG
              @tig said:
              But the curve to bend it around would need to be equally divided up so then you have the form anyway ?
              True! ☀
                TIG, thank you for those plugins. Your first one gives the same result as the method I described using Radial Bend but I think it is a little more straightforward if you know the radius.
                • TIGT Online
                  I'll split them off into a new thread...
                  • X Offline
                    xrok1
                    Link?
                    “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                    • TIGT Online
                      @xrok1 said:
                      Link?
                      The original posts are individually linked to the new 'Plugin' post - or find it here http://forums.sketchucation.com/viewtopic.php?p=359659#p359659
                      • X Offline
                        xrok1
                        Thanks! 😄
                        • 2 / 2
