    House Paint texture
    14 Posts 5 Posters 2.3k Views 5 Watching
    • M
      MrMikeEsq
      Can anyone help me find a texture suitable for a house?
      The house is white. All I can find online are non-seamless, or too over the top with the bumpiness and imperfections.
      But using just a SU plain white texture wont do either!
      Mike
      • massimoM
        massimo Moderator
        White plaster? White wood? White bricks? White concrete? White metal?...
        How is the surface? Have you a reference photo?
        • M
          MrMikeEsq
          Just an exterior paint texture, but with some bump. I would be doing it just flat colour but I want to add a tiny hint of texture to help with the detail (gonna be in Lumion)
          • massimoM
            massimo Moderator
            Something like this?
            Do you need also a bump map?
            • M
              MrMikeEsq
              The second one there is perfect! Thank you πŸ˜„
              Did you already have these? I can't find anything good myself πŸ˜•
              If you don't already have bumps I'll go about generating one myself πŸ˜„
              Again thank you ❗
              • massimoM
                massimo Moderator
                I've made those with Pixplant from not seamless free images found on the net. Here you have some more maps of the second texture. πŸ˜„
                • M
                  MrMikeEsq
                  Fantastic πŸ˜„
                  I'll have to learn how to make seamless textures I think!
                  • massimoM
                    massimo Moderator
                    Well there are a lot of tutorials about using, for example, the offset filter+stamp tecnique in photoshop. Or plugins for PS (tiler for example), that work well with particular kind of images. Or, finally, you have software like Pixplant that are useful both for generating seamless textures and the other maps as well starting from a photo. πŸ˜‰
                    • M
                      MrMikeEsq
                      I think I'll work towards getting Pixplant. Like the multi-functionality of it
                      • soloS
                        solo
                        πŸ‘
                        Massimo to the rescue once again, dude you must have a brilliant texture library as you always have what I'm looking for also.
                        http://www.solos-art.com
                        • massimoM
                          massimo Moderator
                          You're welcome guys. πŸ˜„
                          Well, I have some. πŸ˜‰
                          • T
                            tomsdesk
                            these are super, thank you very much!
                            2.5D Trees & Shrubs!
                            • marleusM
                              marleus
                              Thanks Massimo πŸ‘ πŸ‘
                              These were just what I needed for a render...
                              been looking for these
                              Markus Sillander
                              Vantaa, Finland
                              I'm on FormFonts now
                              http://www.formfonts.com
                              • massimoM
                                massimo Moderator
                                My pleasure. πŸ˜„
                                I have those at higher resolution if you need.
