    House Paint texture
    14 Posts 5 Posters 2.3k Views 5 Watching
    • massimoM
      massimo Moderator
      White plaster? White wood? White bricks? White concrete? White metal?...
      How is the surface? Have you a reference photo?
        MrMikeEsq
        Just an exterior paint texture, but with some bump. I would be doing it just flat colour but I want to add a tiny hint of texture to help with the detail (gonna be in Lumion)
        • massimoM
          massimo Moderator
          Something like this?
          Do you need also a bump map?
            MrMikeEsq
            The second one there is perfect! Thank you πŸ˜„
            Did you already have these? I can't find anything good myself πŸ˜•
            If you don't already have bumps I'll go about generating one myself πŸ˜„
            Again thank you ❗
            • massimoM
              massimo Moderator
              I've made those with Pixplant from not seamless free images found on the net. Here you have some more maps of the second texture. πŸ˜„
                MrMikeEsq
                Fantastic πŸ˜„
                I'll have to learn how to make seamless textures I think!
                • massimoM
                  massimo Moderator
                  Well there are a lot of tutorials about using, for example, the offset filter+stamp tecnique in photoshop. Or plugins for PS (tiler for example), that work well with particular kind of images. Or, finally, you have software like Pixplant that are useful both for generating seamless textures and the other maps as well starting from a photo. πŸ˜‰
                    MrMikeEsq
                    I think I'll work towards getting Pixplant. Like the multi-functionality of it
                    • soloS
                      πŸ‘
                      Massimo to the rescue once again, dude you must have a brilliant texture library as you always have what I'm looking for also.
                      • massimoM
                        massimo Moderator
                        You're welcome guys. πŸ˜„
                        Well, I have some. πŸ˜‰
                        • T
                          tomsdesk
                          these are super, thank you very much!
                          2.5D Trees & Shrubs!
                          • marleusM
                            marleus
                            Thanks Massimo πŸ‘ πŸ‘
                            These were just what I needed for a render...
                            been looking for these
                            Markus Sillander
                            Vantaa, Finland
                            I'm on FormFonts now
                            http://www.formfonts.com
                            • massimoM
                              massimo Moderator
                              My pleasure. πŸ˜„
                              I have those at higher resolution if you need.
