    House Paint texture
    14 Posts 5 Posters 2.1k Views 5 Watching
      MrMikeEsq
      Just an exterior paint texture, but with some bump. I would be doing it just flat colour but I want to add a tiny hint of texture to help with the detail (gonna be in Lumion)
      • massimoM
        massimo Moderator
        Something like this?
        Do you need also a bump map?
          MrMikeEsq
          The second one there is perfect! Thank you πŸ˜„
          Did you already have these? I can't find anything good myself πŸ˜•
          If you don't already have bumps I'll go about generating one myself πŸ˜„
          Again thank you ❗
          • massimoM
            massimo Moderator
            I've made those with Pixplant from not seamless free images found on the net. Here you have some more maps of the second texture. πŸ˜„
              MrMikeEsq
              Fantastic πŸ˜„
              I'll have to learn how to make seamless textures I think!
              • massimoM
                massimo Moderator
                Well there are a lot of tutorials about using, for example, the offset filter+stamp tecnique in photoshop. Or plugins for PS (tiler for example), that work well with particular kind of images. Or, finally, you have software like Pixplant that are useful both for generating seamless textures and the other maps as well starting from a photo. πŸ˜‰
                  MrMikeEsq
                  I think I'll work towards getting Pixplant. Like the multi-functionality of it
                  • soloS
                    πŸ‘
                    Massimo to the rescue once again, dude you must have a brilliant texture library as you always have what I'm looking for also.
                    • massimoM
                      massimo Moderator
                      You're welcome guys. πŸ˜„
                      Well, I have some. πŸ˜‰
                      • T
                        tomsdesk
                        these are super, thank you very much!
                        2.5D Trees & Shrubs!
                        • marleusM
                          marleus
                          Thanks Massimo πŸ‘ πŸ‘
                          These were just what I needed for a render...
                          been looking for these
                          Markus Sillander
                          Vantaa, Finland
                          I'm on FormFonts now
                          http://www.formfonts.com
                          • massimoM
                            massimo Moderator
                            My pleasure. πŸ˜„
                            I have those at higher resolution if you need.
