    [Plugin] Drape Materials v1.0 20111003
    10 Posts 7 Posters 17.0k Views 7 Watching
      Copyright 2011, TIG (c)
      Permission to use, copy, modify, and distribute this software for any
      purpose, and currently without fee, is hereby granted, provided that
      this text and the above copyright (c) notice appear in all copies.
      This software is provided "as is" and without any express or implied
      warranties, including, without limitation, the implied warranties of
      merchantability and fitness for a particular purpose.
      Menu: 'Plugins' > 'Drape Materials'
      OR
      Ruby-Console/Code: TIG-drapematerials
      Usage:
      This tool is designed to drape the materials from the faces you have used
      to drape a 'cutout' onto a surface.
      First use the Sandbox Tool > Drape to drape the faces onto the surface...
      OR EEbyVectorToObject Tool to extrude the faces' edges onto the surface,
      then erase unwanted geometry and explode the group to intersect with the
      surface.
      Preselect the surface's faces that now include the 'cutout' areas - you
      need not be too careful as things other than faces in the selection are
      ignored & surface-faces not immediately below the upper faces are ignored.
      Activate the Tool and the materials from the upper faces are reproduced on
      the cutout faces on the surface.
      It is one step undoable.
      Donations: PayPal.com to info @ revitrev.orgPayPalButton###
      Version:
      1.0 20111003 First issue.
      Put the .rb file into the Plugins folder and restart Sketchup, follow the instructions...drapematerials1.PNGdrapematerials2.PNG
      • W Offline
        wyatt
        This is great! Thank you, TIG.
          Ah yes! I've wanted this!
            Excellent plugin. I broke it already. 😄
            Actually, I think Drape failed and not the plugin.
            231.skp
              Try EEbyVectorToObject for an alternative way of making the 'drape'...
              That might work better.
              Also please make sure that the objects' size are reasonable - I had to introduce a size limit for checking faces so can you try scaling up and see if that helps... for now...
              I plan to look at 'SuperDrape' tomorrow... where it will do the whole draping thing like Sandbox Tools - BUT keeping the draped surface's materials on the drapee surface... watch this space...
                My new 'Super Drape' - that drapes one group onto another, and repeats the materials and texture UVs - is almost ready to publish - watch the forums tonight... Just debugging it... 🤓
                • jolranJ Offline
                  jolran
                  A new hatch tool 😮
                  Ahh, It's for surfaces..
                  Looks sweet!
                    ***SuperDrape*** is here and somewhat makes this tool redundant http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                    • W Offline
                      wq418
                      great!!!!
                      it's awesome
                        ansdud
                        It works perfectly.
