    DXF import
    10 Posts 2 Posters 607 Views 2 Watching
      MrMikeEsq
      Hello,
      I've got 3 discs full of models from Kermi showers, all in DXF. I can open them in Autocad but not SU8 Pro,
      Whats the best procedure?
      Mike
        Sup v8 Pro will import DXF files.
        What is the problem exactly? ... πŸ˜•
          MrMikeEsq
          Oh sorry I should have been clearer, when I try to use the native DXF import it fails, I just can't work out why
            Do you get error messages?
            What 'version' are the DXF files?
            Can you 'save_as' an earlier version from CAD...
            Could you provide one DXF file we can test?
              MrMikeEsq
              Here's a random example (I have a few Gigabytes worth..)
              I don't get any helpful error message, it just says that it failed
              If I save from cad as a different file it doesn't convert well/correctly
              example file dxf
                Ii imports OK for me, with the following options set [or mostly NOT set!]Capture.PNG The DXF units seem to be 'meters'...CaptureSKP.PNG I suspect that you were using small units and the geometry made was so small SUp/OpenGL couldn't support it so you got nothing.
                Once you've done one and the DXF import settings are OK you can do a batch import from a folder using my batchimporter - http://forums.sketchucation.com/viewtopic.php?p=331966#p331966
                Each DXF should import as a component - that way you can then save as a 'collection' of SKPs to a folder from the Component-Browser etc... You then have your DXFs as SKPs...
                  MrMikeEsq
                  That wasn't it πŸ˜•
                  Only got to try today cause its my work pc.
                  I've downloaded free version of SU7, opening them there, then saving the .skp and opening it in my SU8.
                    BUT it imports just fine for me in v8 OR v7...
                    As long as have all of the options unchecked and meters set as the units it should work OK.
                    Assuming all of the DXFs have the same units they should all import OK - my batch-importer would process a folder full automatically πŸ˜•
                      MrMikeEsq
                      Yep I know your way should work, I can import them fine in 7.
                      Obviously some problem with my SU8..maybe a re-install is in order..
                        Sounds like your v8 DXFimporter is foobar - reinstall it...
