    Is there a plugin to select all lines?
    6 Posts 5 Posters 608 Views 5 Watching
      atired
      I need to hide all lines in a terrain. There are hundreds of them. I don't want to select one by one. Is there a plugin to select all lines within a group or component?
      Thanks in advance
        Jim
        Yes there is - http://forums.sketchucation.com/viewtopic.php?t=14975
        but you can also do this by going to Wireframe mode, selecting the edges with the mouse, then hiding them (Edit > Hide.)
          Selection Toys let you filter your current selection: http://forums.sketchucation.com/viewtopic.php?t=14975
          Select Everything
          Then filter that to Select Only > Edges
          (wham! beaten by Jim)
          • Didier BurD Offline
            Didier Bur
            This one http://rhin.crai.archi.fr/rld/plugin_details.php?id=318 can also do that (and some more).
            DB
              There are lots of such tools - several do much more than you ask - try them.
              Here's a simple one-liner that simply adjusts the current selection so it is just edges - copy+paste the code into Ruby Console + <enter>
              (s=Sketchup.active_model.selection).each{|e|s.remove(e)unless e.class==Sketchup;;Edge}
                atired
                I used the "select only tools"
                http://forums.sketchucation.com/viewtopic.php?t=24474
                and then the "solid inspector"
                http://forums.sketchucation.com/viewtopic.php?t=30504
                . They did the job nicely.
                Thanks a lot, everybody.
