Is there a plugin to select all lines?
I need to hide all lines in a terrain. There are hundreds of them. I don't want to select one by one. Is there a plugin to select all lines within a group or component?
Thanks in advance
Yes there is - http://forums.sketchucation.com/viewtopic.php?t=14975
but you can also do this by going to Wireframe mode, selecting the edges with the mouse, then hiding them (Edit > Hide.)
Selection Toys let you filter your current selection: http://forums.sketchucation.com/viewtopic.php?t=14975
Select Everything
Then filter that to Select Only > Edges(wham! beaten by Jim)
This one http://rhin.crai.archi.fr/rld/plugin_details.php?id=318 can also do that (and some more). -
There are lots of such tools - several do much more than you ask - try them.
Here's a simple one-liner that simply adjusts the current selection so it is just edges - copy+paste the code into Ruby Console + <enter>(s=Sketchup.active_model.selection).each{|e|s.remove(e)unless e.class==Sketchup;;Edge} -
I used the "select only tools"
http://forums.sketchucation.com/viewtopic.php?t=24474and then the "solid inspector"
http://forums.sketchucation.com/viewtopic.php?t=30504. They did the job nicely.
Thanks a lot, everybody.
