    Dimensions in SketchUp don't stay in position
    5 Posts 3 Posters 2.2k Views 3 Watching
    • dereiD Offline
      derei
      Placed dimensions inside group don't preserve position when I close the group.
      Below you can see print-screen, also sketchup model.
      this is how dimensions should look-like
      this is how dimensions look after closing the group
      sketchup model
      DESIGNER AND ARTIST DEREI.UK
        mwm5053
        That's strange to say the least. Maybe the group wasn't open for edit I don't know but I did figure out how to fix it.
        I exploded group and went to edit- select all and regrouped it now their were you want. You may have your own reason for putting dim. in group but I would add a layer for dim. to show or hide them. You could group dim. if you wanted. On more complex models that would be they to do best. In layering I learned to name dim. with a z- in layer name so they showed up in layers list at bottom good reasoning behind that also.
        fixed
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • dereiD Offline
          derei
          ...so, it might be a SketchUp bug? Hmm...
          Anyway, the reason for grouping all together is not important, as it was a temporary action. The fact itself is. If it's a bug, it should be fixed.
            I guess the group's axes' directions and the model's axes' directions differ ?
            Try exploding the group in place and immediately regrouping it so the axes reset, re-dimension and see if the dims are then fixed...
            If it's a component then you can try resetting the component's axes to mimic the model's axes directions etc.
            • dereiD Offline
              derei
              indeed, the axis were different. But I'm thinking now that the cause was a earlier mirroring, because after exploding/regrouping I changed the axis again, and everything stayed in place.
