    Back up files in component library
    7 Posts 4 Posters 439 Views 4 Watching
      samyell77
      Is it possible to prevent SU from seeing skb files in a component library folder. Ive saved out several large libraries and have skb and skp files in the folder but SU shows both types and doesn't allow me to see which is which - is there any way to prevent skb files from being on view in the component browser?
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        Why not just erase all the .skb files?
          samyell77
          Just cos I thought it was a good idea to have a back up and I was trying to avoid having to keep turning the 'save backup' preference on and off, or to keep having to move the skb files any time I make a change to the original. Thought there might be a way to view skp files only and not have to keep moving the backup files out of the folder.
          SU Pro 2016
          PC Windows 10
          16gb RAM
            The skb is one step behind the skp in case the skp is corrupted by your editing.
            You should remove unneeded skb files.
            If you are editing a skp in a component library folder I suggest that copy it to a temporary location [e.g. your Desktop... or a folder on your Desktop ?] - then edit it there - a skb will be made in case of balls ups as you edit/save.
            When you are happy with the undated skp, save it and move it back into the component library folder.
            Erase the unwanted skb files at your leisure...
            Now your MAC will only show the skp files because there will not be any skb files in the component library folders!
              samyell77
              Ok - will edit them in a separate location as suggested.
              SU Pro 2016
              PC Windows 10
              16gb RAM
              • E Offline
                ericschimel
                I hate how Sketchup for Mac does this. The Windows version of Sketchup will not show .SKB's in the component browser....
                There is a trick you can do with Spotlight to search all the .SKB's in a directory, and all the subdirectories of a folder so you can delete them in one fell swoop. It's been a while since I've done that trick though.
                -Eric
                http://plugin.sketchthis.net
                Sketchup Kitchen Design Plugin
                Custom Models
                  samyell77
                  Thanks for that - yes it is really annoying. I'll try your spotlight search to get rid of the SKBs.
                  Cheers
                  Sam
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
