    [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
    55 Posts 29 Posters 123.3k Views 29 Watching
    • fredo6F Offline
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      ReportLabelArea is a standalone script which provides several services about Areas:
      • Reporting: Compute and display the area of the selection or the whole model, by materials, by components and groups, and by layers. Display is done in a Web dialog box, with possibility to print and Export in CSV format.
      • Browsing: Indicate the Area of faces, components and groups by mouse-over in the model
      • Labelling: Create and Edit text labels with Areas
        For all functions, there is a choice of Area formatting (unit and decimal), regardless of the default unit of the model.
      This follows a request by vanderlm.
      http://forums.sketchucation.com/download/file.php?id=49285
      ReportLabelArea is now installed as part of FredoTools.
      See the main post for FredoTools for Installation
      http://forums.sketchucation.com/download/file.php?id=49286
      No user manual (see section Quick Start and Videos below)
      • Language: English, French
      • Menus: by default, it is installed in Tools > FredoTools with 2 submenus: Report on Areas and Label with Areas. It also appears in the Contextual menu when there is at least one face in the current selection
      • Icon toolbar: Fredo6 Tools. By default, the 2 icons are not shown
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49284
      Reporting on Areas
      [flash=640,480:19xwnihf]https://www.youtube.com/v/bjbJO717Cyo&hl[/flash:19xwnihf]
      Browsing for Areas and Labelling
      [flash=640,480:19xwnihf]https://www.youtube.com/v/Bu31TpMq3pY&hl[/flash:19xwnihf]
      http://forums.sketchucation.com/download/file.php?id=49288
      Reporting on Areas
      • Call the Plugin on the selection (main menu or contextual menu “Report on Areas”). If there is no selection, ReportArea will operate on the whole model
      • A web dialog box appears showing the report
      • You can change the formatting of areas, unit and number of decimals
      • Report is available by Material, by Layer and by Container
      • You can print the report and export it as a CSV file
      Browsing the model for Areas
      The best is to follow the video
      • Call the menu “Label with Areas”).
      • Mouse over the model to display the area of faces, groups and components. You have several options, like "select single face, as opposed to surface", "select compoents / groups recursively or not"
      • You can change the formatting of areas, unit and number of decimals at any time
      • If you click on elements, they are stored in a temporary selection and the total area of the elements selected is displayed in the top dialog box
      Creating and Editing Labels with Areas
      • On a face or Container, Click and Drag to create and position a new label
      • You can drag the text of the label around
      • You can also move the anchor (mouse over it, a small yellow circle appears, click and drag)
      • to change the formatting of the label, change the unit / decimal in the dialog box and click on the label to update it
      • to Edit the text, double-click on the label
      http://forums.sketchucation.com/download/file.php?id=49289
      ReportArea 3.2a - 05 Feb 20: includes material coming from object painting, when the material on faces is the default material.
      ReportArea 3.1e - 02 Nov 19: Refresh buttons, more options for Export, cosmetic adjustments and bug fixing
      ReportArea 3.0a - 16 Oct 19: This release introduces a new view / report called Outliner
      ReportArea 2.1b - 11 Nov 17: This release fixes a bug in ReportLabelArea when exporting CSV in non-English language
      ReportArea 2.1a - 09 Jul 15: This release fixes a major bug. Now the calculated area takes into account the glued component in Cut opening mode.
      ReportArea 2.0a - 19 Dec 11: This release includes a Reporting with a Web dialog, by Material, by Layer and by Container. It also includes the Browsing and Labelling features.
      ReportArea 1.1a - 11 Sep 11: initial public release
      Z 1 Reply Last reply Reply Quote 0
      • srxS Offline
        srx
        Thanks 😄
        www.saurus.rs
        • P Offline
          Panga
          Thanks a lot for this one Fredo !! Really usefull for me. 👍 👍
            baldaman
            Thanks FREDO!
            Would it be difficult to add "by layer"?
              Ben Ritter
              Thank you.
              • fredo6F Offline
                fredo6
                @baldaman said:
                Thanks FREDO!
                Do you mean
                • compute total area by layer?
                • For each layer, gives the details by Material and by container?
                Fredo
                  baldaman
                  I mean compute total area by layer.
                  I explain: I am doing a big project. I put each floor's top face on adifferent layer corresponding to the affectation of the floor (for exemple: exhibition, administration, library etc...). Each time I want to check the total area of library's floor for exemple, I select one face, right click, and go into context menu and choose "by layer" to have the sum of all areas of library's floors top faces. I do that 40 times a day.
                  I think that if we can make a report of all areas of these faces we can produce an automated area table for elements of program.
                  Of course it could be done with materials, but we often want to give the same material to all the floors. The differenciation comes with layers.
                  Switching to "color by layer" mode gives a more analytical vision.
                  "color by layer mode" = analytical, programmatic
                  "textured mode" = realistic, rendering.
                  Sorry for my frenglish.
                  • Chris FullmerC Offline
                    Hmm, I just wrote a very simple version of this for myself today. I should have looked here first. oops! Thanks for the script Fredo,
                    Chris
                    All my Plugins I've written
                    • mitcorbM Offline
                      mitcorb
                      Thank you, Fredo6:
                      An excellent concept. 👍 👍
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: ReportLabelArea 2.0a - 19 Dec 11
                        ReportLabelArea is a rework of the previous ReportArea standalone plugin. It provides:
                        • More visual features for Reporting and Browsing for Areas
                        • Creation, update and Edition of labels with Areas
                        • Area formatting (choice of unit and decimals) for all functions
                        There are two videos to give an idea of the main features of the plugin
                        ReportLabelArea is now published as part of the FredoTools suite of Plugins
                        See main post of this thread for more information.
                        Fredo
                          boilingsnow
                          Fredo is generous.
                          Thank you.
                            boilingsnow
                            Could you make them separate to install?
                            • fredo6F Offline
                              fredo6
                              What do you mean?
                              Fredo
                                tak2hata
                                This is nice tool!
                                Thanks FREDO! 😍
                                by TAK2HATA
                                  boilingsnow
                                  What do you mean?
                                  Fredo
                                  I mean you are providing a set of tools and I have to install them all at one time. But I have already installed some of them and made my own icons for them.
                                  Actually I am using sutool of Wikii as a manager of all my plugins. And this set of combined tools doesn't support that.
                                  I konw I can also control display of the icons through your LibFredo6, but it would still be wonderful if you could continue providing these tools als seperate plugins at the same time.
                                  • fredo6F Offline
                                    fredo6
                                    I understand.
                                    I am not a user of Wikii's SUTool. Can you tell me how you bind the icon / command to the Plugin.
                                    I can try to offer an interface which is compliant so that you keep seeing the plugins as standalone.
                                    Fredo
                                    PS: I regrouped the plugins to minimize the footprint in SU, (i.e. have a single menu item). I also provides a Quick Launcher.
                                      boilingsnow
                                      I understand.
                                      Fredo
                                      Thank you very much for your answer.
                                      • I Offline
                                        I.Aleks.S
                                        [size=150]NEW RELEASE: [color=#400000]**ReportLabelArea 2.0a - 19 Dec 11....
                                        [/bFredo
                                        Hello [b]Fredo6**.
                                        Forgive for my bad English.
                                        I use many yours Plugins. I give an appreciation on these workings out.
                                        I address to you with the request, to make calculation function on length;
                                        Millimetres running
                                        Centimetres running
                                        Metres running.
                                        Probably to execute it?
                                        I thank you.
                                          jorge2011
                                          fredo excellent tool. thank you very much.
                                          A query. You can add a tool to measure length of vectors, curves, polylines etc ...?
                                            cyb
                                            Fredo. Great Tool.
                                            One question. The sorting is by either Material or by Layer.
                                            Any chance to add By Layer then by Material?
                                            Something like this?
                                            Layer1
                                            Material 1
                                            Material 2
                                            Material 3
                                            Layer2
                                            Material 1
                                            Material 2
                                            Material 3
                                            Regards.
                                            • 1 / 3
