    [Plugin] Follow Me Helix (Updated 06-Jan-2012)
    45 Posts 17 Posters 35.4k Views 17 Watching
      crazac
      Yea, thanks for this, it's an awesome plug.
      I do have a question tho, I can only seem to make it revolve in one direction. Putting negative numbers in the fields produces the beach ball of death and a force quit. I've also tried adjusting the path direction to no avail. Is there a way to make the helix revolve in the opposite direction?
      • sdmitchS Offline
        sdmitch
        No there is currently no way to make it go the other way. I will take a look and see what I can do.
        http://sdmitch.blogspot.com/
        • mitcorbM Offline
          mitcorb
          In the meantime you could use Flip Along or Mirror.rb?
          • soloS Offline
            solo
            I don't see the point to reversing this, it's follow the line right?
            http://www.solos-art.com
              @mattarth said:
              I would like to draw a barrel spring.
              Thanks in advance,
              Matt
              Matt, how accurate does your barrel spring need to be? Would this one play for you?
              http://farm7.static.flickr.com/6106/6211771064_a30af04cce.jpg
              This was easy enough with Draw Helix and Follow Me. I didn't bother with the ends but they would be trivial, too.
                crazac
                Thanks sdmitch, that would be great!. I really appreciate this plugin. I didn't have much hope when i started this project until i found it. 👍
                mitcorb, thanks for the heads up. The Mirror is handy, but isn't producing the result i'm after. The helix needs to be inverted...
                • sdmitchS Offline
                  sdmitch
                  In case you missed it, I posted an updated version yesterday that, if negative angular increment is entered, reverses the direction of the helix.
                    crazac
                    AWESOME!, I did miss it, it works great! Thanks a lot, I really appreciate it...
                      mattarth
                      @dave r said:
                      Thanks in advance,
                      Matt
                      This is great, DrawHelix is exactly what I needed to know, thank you.
                      I've since tried to make it using a spiral road intersected with a barrel shape:
                      http://farm7.static.flickr.com/6050/6217456920_0416623e75_z_d.jpg
                      but it wouldn't follow the whole curve, only the upper or lower half (I was getting the "this does not appear to be a valid path" error when I tried to follow the curve as a whole).
                        Matt, I used Draw helix to draw three different helices. All three have the same pitch. The first was the bottom, straight helix for 5 turns (because that was the default number when the plugin launched) and it got copied up for the top straight section. The second helix tapers from the first helix's radius out to the larger radius. I copied and flipped the copy to make the top taper as well. That one also has 5 turns. Then there's a three-turn straight helix for the center part of the spring.
                        All these helices are created as groups which I exploded. Then I welded them together to make them easier to select as a path for Follow Me. It's an instant spring but it doesn't take that long to do. I definitely make a component of the spring so I could easily reuse it.
                          mattarth
                          Thanks Dave, I think I'll use your method from now on. It's the neatest way to make barrel springs.
                          Although the intersection method would allow someone to make more interesting profiles if they needed to, if they could tolerate the time it takes for SketchUp to calculate the new path and then follow it 😄
                            You're welcome. I think it is useful to know both methods. Sometimes one will be more useful than the other. For example I used that method for drawing these ironwork baskets. I couldn't get the proper helix using the Draw Helix plugin. Tools on Surface is ideal for drawing the helix on the extruded shape.
                            http://farm7.static.flickr.com/6027/5970412478_9bb8eea837.jpg
                            • 8 Offline
                              8068
                              Thank You!
                              Really
                                buddyholly27
                                First off, thank you for such a useful plugin - I've been making handrails for spiral staircases so it's been invaluable.
                                I've had a couple of problems with fractions on making higher resolution helix. My working figures have been for 194mm riser at radius 1150mm with risers at 30 degree increments but when I subdivide my figures to create a smoother helix a bug seems to appear (disclaimer, my maths isn't so hot but I've checked as far as I can). so, doubling resolution to 97 and 15 works as expected but doubling again to 48.5mm and 7.5degrees causes the dialogue to disappear with no geometry result. Has anyone else encountered this, or can maybe suggest a way I can create a smoother helix curve?
                                ps though I've been a daily reader for quite a while this is my first post to SketchUcation so apologies for the clunkiness of this mail!
                                • sdmitchS Offline
                                  sdmitch
                                  The problem is with the plugin. It only accepts interger angles in its present form so the 7.5 causes an error. If you divide linear and angular increments by 5 and use 38.8 and 6 that will work. The smaller the angular increment the smoother the helix.
                                    buddyholly27
                                    Thanks sdmitch! That'll do the trick and might save others a little time too. Great plugin. Not only did it save me time, but I couldn't see another way of resolving my modeling challenge. Cheers BuddyH
                                      Why not fix it ?
                                      @radius=1.feet if !@radius;@dist_inc=1.inch if !@dist_inc;@ang_inc=30****.0**** if !@ang_inc prompts=["Radius of helix:","linear Increment:","Angle Increment:"] ans=UI.inputbox(prompts,[@radius,@dist_inc,@ang_inc],"Helix Generator") if !ans then;return;end @radius=ans[0].to_l;@dist_inc = ans[1].to_l; @ang_inc=ans[2].to_****f****
                                      If a dialog has a value set as an integer it can thereafter only accept an integer as its input.
                                      So just make the initialized @ang_inc a float by using a float value.
                                      [ 30.0 and NOT an integer like 30 ] 😒
                                      And also never change the @ang_inc into an integer with .to_i later on.
                                      • charly2008C Offline
                                        charly2008
                                        Hi Jon,
                                        The technique for a curved spiral is "Follow Me Helix" and "Shape bender". The better is the combination "DrawHelix" and "Shape bender". there is a better control about the helix.
                                        Charly
                                        • sdmitchS Offline
                                          sdmitch
                                          TIG, fixing it is as simple as you suggest in making the angle increment a float. My original obviously flawed assumption was that there would never be a need for an increment less than a degree.
                                            shingabiss
                                            I downloaded this and added it but can't seem to find it in any toolsets. Where does it reside in the menus?
                                            • 2 / 3
