    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Intersect Model with Section Cut
    scheduled pinned locked moved Plugins
    10 Posts 5 Posters 2.0k Views 5 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
      I thought there was a SketchUp function that intersected a model by a section cut. But I seem to be wrong. And now I'm trying to find a plugin that does that.
      Anyone?
      one-reply-to-this-post last-reply-time reply quote 0
      • massimoM Offline
        massimo Moderator
        Zorro has a context menu feature "slice model at section". πŸ˜‰
          Context-menu... my SectionCutFace [to add a 'faced' group at the cut], or Zorro2 [Slice Model at Section]?
          Native: if you right-click a section-cut you also get 'Create Group from Slice' [about seven items down] which makes a grouped, but unfaced, set of lines at the cut-plane...
          To mimic it in code make a group with a large face - bigger than the model.bounds, centered on the section-plane, then group.entities.intersect_with(...) the model.entities.to_a, putting the resultant edges into the group.entities. erase the outer edges of the temp-face and then any faces left in the group to leave the edges ???
          • KrisidiousK Offline
            Krisidious
            SectionCutFace is what I use.
            By: Kristoff Rand
              Trying Zorro2 now. Taking a loooong time.
              One thing: do any of these tools separate the cut geometry?
              What I really want to do is get two groups with the two halves. So I can either erase or hide of them.
                Zorro2 erases the 'half' you can't see...
                To get the model split into two parts you'd need to do it twice, on two copies, with the section-cut reversed in one of them.
                You could them copy and paste-in-place from these two processed SKPs into a new model so that the whole model is there again - but now 'split'...
                  For now that is ok. But I'm running into BugSplats. 😞
                    I posted a fix on the Zorro thread in response to your comment there... http://forums.sketchucation.com/viewtopic.php?p=350060#p350060
                    • F Offline
                      figaro
                      where can i download the section cut face plugin?
                        First post in its thread - get that from the Plugins Index [BIG red button above here]
                        • first-post
                          last-post
