    How to change position of a copied form ?
    10 Posts 3 Posters 466 Views 3 Watching
    • E Offline
      erzane
      hi !
      I would like to now how to past this element to another angular side of the wall
      http://img706.imageshack.us/img706/5839/captureqw.jpg
      p.s. I know how to past it to the same wall or same linearity but I just dont know how to make it with a different side of the wall , different angle, disposition, how to turn it on and paste it correctly
      thanks
      • mitcorbM Offline
        mitcorb
        Have you tried this? If it is a component, right click and Unglue?
        • E Offline
          erzane
          in another topic I studied components but I totally forget how to create it, I lost the conversation file unfortunately
          I tryed to create a component but without success, I dont like so much creating component because it seems to be so much complicated
          pls can you explain it to me one more time step by step ?
            When you have the 'copy in space' - use Make Group - the easiest... [OR use Make Component]
            The objects are then collected into one thing that you can more easily move, rotate etc into place...
            • E Offline
              erzane
              I notified that if I select the part I want to copy and make CTRL+C
              and after that CTRL+V the form will position itself more easy on the surface I want
              after that I right click and select ''make a group'' like you told me and like this I can rotate it with the 'Q' tool.
              but the problem is that, I cannot separate the pasted form from the surface
              pls see example (all is selected, I cannot select only one circle if I want to modify it)
              http://img840.imageshack.us/img840/1604/capt11020162525001.jpg
                If you have grouped something and it sticks to a surface then you can right-click context-menu "Unglue" so it then moves freely...
                • E Offline
                  erzane
                  I made CTRL+V, my element is pasted, after I right click for ''creat a groupe''
                  after I select rotation (Q) tool and I rotate my element by typing ''90'' degree rotation
                  and after that I right click on my element and I have choice to unglue but not the all element is unglued
                  http://img560.imageshack.us/img560/900/capt11020165957001.jpg
                  I can move freely only one
                  http://img27.imageshack.us/img27/4827/capt11020170101001.jpg
                  http://img263.imageshack.us/img263/7254/capt11020170257001copie.jpg
                    Try making copy+paste, then make group, then unglue it, then move or rotate it - in that order 😕
                    • E Offline
                      erzane
                      ok thanks
                      • mitcorbM Offline
                        mitcorb
                        hi, erzane:
                        I think in your last image above, you did not include that remnant in your selection before moving the selection. Maybe not. But it kind of illustrates the good practice of making a component as soon as you have constructed an assemblage of unique geometry. You do not have to give the component a unique name right away, if it interferes with your workflow, but is good to go back and name it, even set up layers to place these components. After all the time I have been using Sketchup(a few years), this is finally sinking in to my thick head.
