Material Reflection won't show
Hi, I've been having problems when rendering my views in VRay. Some of the materials won't show in the reflection. The object reflects but with only the default sketchup material not with the material applied. This often happens to me.
I attached a sample of the rendered image.The floor material which is cement and metal won't reflect but some other materials do. This has happened to several of my models, none of my floors show. I've had to apply it via photoshop T_T. Even the reflected wall on the image behind the shoe rack has a wallpaper material applied but again, it's blank.
Why not post in our V-ray sub-forum ?
Check the direction of your faces. Ensure that you got the front side of the faces in the correct direction.
Register LoginAdvertisement
