    [Plugin] AddPage v1.4 20110810
    7 Posts 5 Posters 7.7k Views 5 Watching
      This is an old script brought into the mainstream from a sub-post... It adds the current Scene-Tab's name to the screen as 'screen-text', visible for that scene only, using a dedicated layer.
      Updated 20110810 v1.4 to have an 'ALL' version that does all scenes at once.PayPalButton
      Put into the Plugins folder and restart Sketchup...
        Thanks TIG 👍
        • 3 Offline
          3dsmax9
          thank's.
          • jim smithJ Offline
            jim smith
            Thanks for the update TIG
            "Out of clutter find simplicity,
            from discord find harmony,
            In the middle of difficulty lies opportunity"
            Albert Einstein
            • G Offline
              glro
              @tig said:
              This is an old script brought into the mainstream from a sub-post... It adds the current Scene-Tab's name to the screen as 'screen-text', visible for that scene only, using a dedicated layer[attachment=0:2w5o75x7]<!-- ia0 -->AddPage.rb<!-- ia0 -->[/attachment:2w5o75x7].
              your plugin is ideal to print a set of views of the model with references
              just a suggestion: possibility to add the title to all the scenes of the model, with only one click (when there are 25 scenes, for example, it would help)
                This http://forums.sketchucation.com/viewtopic.php?p=345385#p345385 is v1.4 that has an option 'ALL' version that processes all scenes in one go...
                • G Offline
                  glro
                  yes, you are right; i had downloaded the plugin here
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                  it works perfectly
                  thank you
