    [Plugin] Simple Scale Tool Handles v1.2 7-25-2011
    49 Posts 19 Posters 38.4k Views 19 Watching
      rv1974
      @kyyu said:
      @rv1974 said:
      Hi Kyyu!
      Could you please make a simple version of the script without any icons and dropdown options?
      Just a distillated simple scale ruby. Please!
      Thank you!
      You really want a one way ruby? copy/paste into ruby console or .rb file.
      UI.menu("Plugins").add_item("simple scale handles"){Sketchup.active_model.definitions.each{|e|e.behavior.no_scale_mask=88}}
      It's gettinng better. There's one last step. Now your simplified script assures that the next scale operation will be with simple handles, correct? What I'd like to get is simplified scale all together at once.
      Thank you so much
      • halroachH Offline
        halroach
        @kyyu said:
        Updated to v1.2, see 1st post. The menu item has always processed the selection, if it exsit. Now the toolbar icons do this, too. But there is an option to change it back to only processing all. See the description. Also, I darkened the icons.
        The last update 1.2 works like expected. It was a bit confusing for me when the menu item was doing something different than what the toolbar was doing.
        By what it looks, basically what the plugin does is change the scale properties for each component, right?
        1. I think some people may confuse this tool as being a separate scale tool that scales only in the XYZ direction...
          but it is actually a tweak for each component to scale differently, with the original scale tool. I guess it is similar to using dynamic component scale attributes (as in the image attached)
        2. would this tweak have any effect on model performance? or file sizes!? When I was using dynamic component attributes for this exact same scaling idea, it used to make overall sketchup performance a bit laggy at times.
        3. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
        thanks!
        same thing using dynamic component attributes
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH Offline
          halroach
          In the latest version 1.2, there is a problem that the simple scale isn't constrained to only X Y Z, but also one more XY... see attached image.
          I used the toolbar to change the properties...
          bug
          • K Offline
            kyyu
            Yes, the user is selecting or processing all components/groups. And I explained, in basically the 2nd sentence of the 1st post that a property of the comp/group was being modified. I get confused myself about other peoples plugins. It's just the nature of things, the wild west of plugins.
            The properties in that picture look very familiar: http://code.google.com/apis/sketchup/docs/ourdoc/behavior.html#no_scale_mask=
            I am using those exact properties, from the SU ruby api. So maybe you will get the same limitations? Big models is kinda outside my knowledge zone. I'm still using an old computer, Pentium 4, but it's enough for my need. Just do small home project with SU.
            1. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
            Of course, anything is possible, but would you spend the time to do it? Probably not, usless it was very important to you. Even this small pugin, I probably spent an evenings time spread over a few days. And I'm no expert, just slowly learning.
            But I see that Fredo6 just put a similar, but real tool mod in his FredoScale plugin. Looks like he is responding to the same request I saw. I just happen to come across a solution and remembered the request. Check it out:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&start=600#p343978
            Yes, I have X,Y,Y and (X+Y). The request was for scaling sheet parts. So X+Y coupling is fine and probably wanted. I just removed all z coupling. If you want, just X,Y,Z; it's easy enough to change:
            Line#56 where it has "e.behavior.no_scale_mask=88" just change the "88" to "120".
            • halroachH Offline
              halroach
              thank you for the long reply!
              That will definitely be of help! thanks of the pointers!
              • jolranJ Offline
                jolran
                Nice icons Kyyu! Very useful plugin.
                • K Offline
                  kyyu
                  Thanks, my 1st icons. I think the most time was spent, just making the icons. 😆
                  • jolranJ Offline
                    jolran
                    He he! Yes I know. It's difficult to make them look good after downscaling so much.
                    Anyway.. Good job 👍
                      rock1
                      i'm having a problem using this tool. when i click either of the two toolbars button, the default scaling handles remain. they never change to the simple scale tool 😕 what should i do?
                      Signature removed by SCF Admin
                      • K Offline
                        kyyu
                        Do you have a group or component, in your drawing, for the plugin to modify? You can give it a try under the plugins menu, but no one else has reported a problem with the toolbar?
                          rock1
                          I did this for group, i even tried from the plugin drop down menu, i select the simple option but the default handles remain 😕
                            Sounds like pilot error. After clicking on the toolbar icon, click on one of the scale handles and they'll change as set by the plugin. 😒
                              rock1
                              i select a box [which is a group], press "s", then click the 1st button of toolbar. nothing happens
                              if i select the box, then click the button, it doesn't get pressed at all 😕
                              • K Offline
                                kyyu
                                Because the scale tool does not know to update it's handles drawing. You have to force it to redraw. Either by selecting a handle, like Dave R, suggested. Or by reselecting the group. Deselect by pressing [Esc]key or right clicking on an empty spot on the screen. And reselect the group.
                                The button doesn't depress for selection. If there is nothing selected, then all active group/components are processed and the button is depressed as an indicator that every thing was processed.
                                  Too bad you didn't read what I wrote. 😒
                                  Thank you, Kyyu
                                  • K Offline
                                    kram2422
                                    Nice one kwok thank you! 👍
                                    Mark and Trish
                                    • sicksickisckS Offline
                                      sicksickisck
                                      😐 don't work at all,it's just empty icons
                                        Sounds like you didn't install it correctly. Most likely you didn't preserve the folder structure.
                                        Have a look at this utility plugin that will make it easier to install plugin correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
                                        Also have a look at this tutorial on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                          TBoy
                                          Is it possible to have simple scale handles as default behavior for scale tool ?
                                            Set up a keyboard shortcut to activate this tool instead of the default Scale tool. S is the default keyboard shortcut for the native Scale tool. Change it to activate this tool instead.
                                            • 2 / 3
