    [Plugin] Simple Scale Tool Handles v1.2 7-25-2011
    49 Posts 19 Posters 42.1k Views 19 Watching
    • jolranJ Offline
      jolran
      Thanks, my 1st icons. I think the most time was spent, just making the icons.
      He he! Yes I know. It's difficult to make them look good after downscaling so much.
      Anyway.. Good job πŸ‘
        rock1
        i'm having a problem using this tool. when i click either of the two toolbars button, the default scaling handles remain. they never change to the simple scale tool πŸ˜• what should i do?
        Signature removed by SCF Admin
          kyyu
          Do you have a group or component, in your drawing, for the plugin to modify? You can give it a try under the plugins menu, but no one else has reported a problem with the toolbar?
            rock1
            I did this for group, i even tried from the plugin drop down menu, i select the simple option but the default handles remain πŸ˜•
              Sounds like pilot error. After clicking on the toolbar icon, click on one of the scale handles and they'll change as set by the plugin. πŸ˜’
                rock1
                i select a box [which is a group], press "s", then click the 1st button of toolbar. nothing happens
                if i select the box, then click the button, it doesn't get pressed at all πŸ˜•
                  kyyu
                  Because the scale tool does not know to update it's handles drawing. You have to force it to redraw. Either by selecting a handle, like Dave R, suggested. Or by reselecting the group. Deselect by pressing [Esc]key or right clicking on an empty spot on the screen. And reselect the group.
                  The button doesn't depress for selection. If there is nothing selected, then all active group/components are processed and the button is depressed as an indicator that every thing was processed.
                    Too bad you didn't read what I wrote. πŸ˜’
                    Thank you, Kyyu
                      kram2422
                      Nice one kwok thank you! πŸ‘
                      Mark and Trish
                      • sicksickisckS Offline
                        sicksickisck
                        😐 don't work at all,it's just empty icons
                          Sounds like you didn't install it correctly. Most likely you didn't preserve the folder structure.
                          Have a look at this utility plugin that will make it easier to install plugin correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
                          Also have a look at this tutorial on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                            TBoy
                            Is it possible to have simple scale handles as default behavior for scale tool ?
                              Set up a keyboard shortcut to activate this tool instead of the default Scale tool. S is the default keyboard shortcut for the native Scale tool. Change it to activate this tool instead.
                              • fredo6F Offline
                                Just for info, FredoScale does this reduction of handle automatically depending on the 'apparent' dimensions along the axes. If you manipulate a thin plate, you'll get one handle, but if you zoom, you will end up by getting 3 as in the native Scale Tool.
                                • JQLJ Offline
                                  JQL
                                  Fredo I had never noticed that. As I'm used to being afraid of Scale tool handles I thought it was better zooming in with yours too... Mindless zooming in and out! Your tools seem to surprise me at every corner with such elaborate features!
                                  www.casca.pt
                                  Visit us on facebook!
                                    TBoy
                                    @fredo6
                                    FredoScale "Box stretching" is most useful in planar editing I think. Default scale tool may modify size in view direction (invisible in 2d view), that's why I wish to replace the default scale tool handles.
                                    Your work is amazing fredo6...
                                    What I really miss in Skethup is some kind of property window or something - showing and modifying real x, y, z size of selected object/s (or/and any kind of selection) in users units. I wander why it is not done yet. I know I can enter exact values with scale tool, but this is NOT a natural way for size editing.
                                    You can do it fredo6.
                                    • fredo6F Offline
                                      I think you can press TAB when the mouse is over a handle and you'll get a dialog box to enter the size.
                                        TBoy
                                        @fredo6 said:
                                        I think you can press TAB when the mouse is over a handle...
                                        Yes, something like this but...
                                        too much clicks to obtain a simple size change.
                                        I started a new topic here:
                                        http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=64170
                                        Please see it.
                                          TBoy
                                          ky, where can I find explanation of those numeric equivalents of the commands you use in this and other scripts?
                                          Thanks for Simple scale handles, it is always ON with "120 mask" in my files.
                                          • CadFatherC Offline
                                            CadFather
                                            use this in the console to find out the integers (also below are some you can use)
                                            @s=Sketchup.active_model.selection;@d=@m.definitions;@s[0].definition.behavior.no_scale_mask = 127  ; Sketchup.send_action('selectScaleTool;')
                                            ALL VISIBLE = 000000 = 0
                                            NO RED = 0000001 = 1
                                            NO GREEN = 0000010 = 2
                                            NO BLUE = 0000100 = 4
                                            NO FREE DEFORM = 0111000 = 56
                                            CORNERS ONLY = 0111111 = 63
                                            NO HANDLES = 1111111 = 127
                                            ONLY AXES = 1110000 = 120
                                            • 2 / 3
