    [Plugin] Simple Scale Tool Handles v1.2 7-25-2011
    49 Posts 19 Posters 39.5k Views 19 Watching
      rv1974
      Hi Kyyu!
      Could you please make a simple version of the script without any icons and dropdown options?
      Just a distillated simple scale ruby. Please!
      Thank you!
      • halroachH Offline
        halroach
        @kyyu said:
        Description: This plugin makes it easier to use the scale tool, on thin sheet parts. When the scale tool is used on a modified component/group, the drag handles are reduces from the normal 26 to only 10. Tested on SU8, and also seems to work with SU7.
        From Plugins Menu: If nothing is selected, than all active groups/components are processed. Run from the Plugins menu: "[ky] Simple Scale Handles"
        Nice plugin!
        Though it doesn't work for me as described. If I select one component, and run the tool, it still effects all of the components, except for components that are within components. No matter what I select, it always effects everything.
        FlexTools - Super Quick Windows, Doors, Slats...
          kyyu
          Nice plugin!
          From the plugin menu? I just double check and it works the way it should. From the toolbar icon, it's supposed to only processes everything (if you look at the next paragraph in the description). The idea was that a depressed icon would indicate, you had processed everything. Although, I could probably set it up so the toolbar can be used with selection and only depress whatever was last all processed. You can still click the icon, when it is depressed. Is that the way people would like to have it set up?
            kyyu
            @rv1974 said:
            Hi Kyyu!
            Thank you!
            You really want a one way ruby? copy/paste into ruby console or .rb file.
            UI.menu("Plugins").add_item("simple scale handles"){Sketchup.active_model.definitions.each{|e|e.behavior.no_scale_mask=88}}
              kyyu
              Updated to v1.2, see 1st post. The menu item has always processed the selection, if it exsit. Now the toolbar icons do this, too. But there is an option to change it back to only processing all. See the description. Also, I darkened the icons.
                rv1974
                @kyyu said:
                @rv1974 said:
                Hi Kyyu!
                Thank you!
                It's gettinng better. There's one last step. Now your simplified script assures that the next scale operation will be with simple handles, correct? What I'd like to get is simplified scale all together at once.
                Thank you so much
                • halroachH Offline
                  halroach
                  The last update 1.2 works like expected. It was a bit confusing for me when the menu item was doing something different than what the toolbar was doing.
                  By what it looks, basically what the plugin does is change the scale properties for each component, right?
                  1. I think some people may confuse this tool as being a separate scale tool that scales only in the XYZ direction...
                    but it is actually a tweak for each component to scale differently, with the original scale tool. I guess it is similar to using dynamic component scale attributes (as in the image attached)
                  2. would this tweak have any effect on model performance? or file sizes!? When I was using dynamic component attributes for this exact same scaling idea, it used to make overall sketchup performance a bit laggy at times.
                  3. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
                  thanks!
                  same thing using dynamic component attributes
                  • halroachH Offline
                    halroach
                    In the latest version 1.2, there is a problem that the simple scale isn't constrained to only X Y Z, but also one more XY... see attached image.
                    I used the toolbar to change the properties...
                    bug
                      kyyu
                      Yes, the user is selecting or processing all components/groups. And I explained, in basically the 2nd sentence of the 1st post that a property of the comp/group was being modified. I get confused myself about other peoples plugins. It's just the nature of things, the wild west of plugins.
                      The properties in that picture look very familiar: http://code.google.com/apis/sketchup/docs/ourdoc/behavior.html#no_scale_mask=
                      I am using those exact properties, from the SU ruby api. So maybe you will get the same limitations? Big models is kinda outside my knowledge zone. I'm still using an old computer, Pentium 4, but it's enough for my need. Just do small home project with SU.
                      1. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
                      Of course, anything is possible, but would you spend the time to do it? Probably not, usless it was very important to you. Even this small pugin, I probably spent an evenings time spread over a few days. And I'm no expert, just slowly learning.
                      But I see that Fredo6 just put a similar, but real tool mod in his FredoScale plugin. Looks like he is responding to the same request I saw. I just happen to come across a solution and remembered the request. Check it out:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&start=600#p343978
                      Yes, I have X,Y,Y and (X+Y). The request was for scaling sheet parts. So X+Y coupling is fine and probably wanted. I just removed all z coupling. If you want, just X,Y,Z; it's easy enough to change:
                      Line#56 where it has "e.behavior.no_scale_mask=88" just change the "88" to "120".
                      • halroachH Offline
                        halroach
                        thank you for the long reply!
                        That will definitely be of help! thanks of the pointers!
                        • jolranJ Offline
                          jolran
                          Nice icons Kyyu! Very useful plugin.
                            kyyu
                            Thanks, my 1st icons. I think the most time was spent, just making the icons. 😆
                            • jolranJ Offline
                              jolran
                              He he! Yes I know. It's difficult to make them look good after downscaling so much.
                              Anyway.. Good job 👍
                                rock1
                                i'm having a problem using this tool. when i click either of the two toolbars button, the default scaling handles remain. they never change to the simple scale tool 😕 what should i do?
                                Signature removed by SCF Admin
                                  kyyu
                                  Do you have a group or component, in your drawing, for the plugin to modify? You can give it a try under the plugins menu, but no one else has reported a problem with the toolbar?
                                    rock1
                                    I did this for group, i even tried from the plugin drop down menu, i select the simple option but the default handles remain 😕
                                      Sounds like pilot error. After clicking on the toolbar icon, click on one of the scale handles and they'll change as set by the plugin. 😒
                                        rock1
                                        i select a box [which is a group], press "s", then click the 1st button of toolbar. nothing happens
                                        if i select the box, then click the button, it doesn't get pressed at all 😕
                                          kyyu
                                          Because the scale tool does not know to update it's handles drawing. You have to force it to redraw. Either by selecting a handle, like Dave R, suggested. Or by reselecting the group. Deselect by pressing [Esc]key or right clicking on an empty spot on the screen. And reselect the group.
                                          The button doesn't depress for selection. If there is nothing selected, then all active group/components are processed and the button is depressed as an indicator that every thing was processed.
                                            Too bad you didn't read what I wrote. 😒
                                            Thank you, Kyyu
                                            • 2 / 3
