    [Plugin] Simple Scale Tool Handles v1.2 7-25-2011
    49 Posts 19 Posters 40.3k Views 19 Watching
    • K Offline
      kyyu
      By request, a plugin to make it easier to use the scale tool, on thin sheet parts. Component/group definitions have a property that hides the handles. When the scale tool is used on a modified component/group, the drag handles are reduces from the normal 26 to only 10.
      Newest is version 1.2
      v1.0 (7-21-2011) initial version
      v1.1 (7-23-2011) added Toolbar
      v1.2 (7-25-2011) Toolbar now processes selection, with option to only process all.
      Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided this notice appears in any copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Author: kyyu (7-25-2011) v1.2
      Description: This plugin makes it easier to use the scale tool, on thin sheet parts. When the scale tool is used on a modified component/group, the drag handles are reduces from the normal 26 to only 10. Tested on SU8, and also seems to work with SU7.
      Activated from (Plugins menu "[ky] Simple Scale Handles") or (Toolbar). If nothing is selected, than all active groups/components are processed. Toolbar icons are depressed, as a visual indicator when all comp/groups are proccessed. Depressed icons can still be clicked, for example to process a selection. There is an option below, for the toolbar to ignore selection.
      Options: There are 3 vaiables at the beginning of the script, whos value can be changed to customize the plugin.
      [menu = true] -load "Plugins Menu item"
      [toolbar = true] -load Toolbar
      [@toolbar_all = false] -if true, Toolbar will ignore selection, and only process all active comp/groups.
      Tip: You need to have the z axis, of group/component, aligned with the thickness of the sheet.
      simple scale handles_v1.2.zip
      • R Do not disturb
        rv1974
        Oh I'm sotired with the default one. Huge thank you!!!
        • KrisidiousK Offline
          Krisidious
          are you saying this flattens stuff?
          By: Kristoff Rand
          • dereiD Offline
            derei
            Simple and Awesome. some things should be by default in SU
            DESIGNER AND ARTIST DEREI.UK
            • kenK Offline
              ken
              This is nice plugin and needed by me since I work in large size 1/4" thick steel plate. I have added a icon and now trying to make the selection of the icon a toggle, Simple to Default and back.
              Thanks for your work
              Ken
              • TIGT Online
                A very simple yet very clever new tool. 🤓
                Which shows us that there are still many new or alternative ideas that can be realized without thousands of lines of code... 😄
                • jolranJ Offline
                  jolran
                  Great tool Kyyu! Thanks.
                    Might want to wrap that up on a start/commit operation so it can be undone in one go.
                      Ben Ritter
                      Thank you very much.
                      • K Offline
                        kyyu
                        No, it changes the apperance of the skechup native scale tool. The right part in the image shows the change.
                          Jim
                          Very handy. Thanks.
                          • K Offline
                            kyyu
                            I had the start/commit operation in there originally, but no undo was created? So I removed it. Any other benifit of having it in there?
                            • TIGT Online
                              kyyu
                              I see what you mean - it seems that the resetting of the scale-handles happens outside of the undo stack ? The definition.behavior.no_scale_mask= seems weird in this respect ? Fortunately you have a simple reset to 'all' in your dialog choices... 😕
                              • K Offline
                                kyyu
                                I added a toolbar. 1st post updated to version 1.1
                                • TIGT Online
                                  Thanks! 😄
                                  • R Do not disturb
                                    rv1974
                                    Hi Kyyu!
                                    Could you please make a simple version of the script without any icons and dropdown options?
                                    Just a distillated simple scale ruby. Please!
                                    Thank you!
                                    • halroachH Offline
                                      halroach
                                      From Plugins Menu: If nothing is selected, than all active groups/components are processed. Run from the Plugins menu: "[ky] Simple Scale Handles"
                                      Nice plugin!
                                      Though it doesn't work for me as described. If I select one component, and run the tool, it still effects all of the components, except for components that are within components. No matter what I select, it always effects everything.
                                      FlexTools - Super Quick Windows, Doors, Slats...
                                      • K Offline
                                        kyyu
                                        Nice plugin!
                                        From the plugin menu? I just double check and it works the way it should. From the toolbar icon, it's supposed to only processes everything (if you look at the next paragraph in the description). The idea was that a depressed icon would indicate, you had processed everything. Although, I could probably set it up so the toolbar can be used with selection and only depress whatever was last all processed. You can still click the icon, when it is depressed. Is that the way people would like to have it set up?
                                        • K Offline
                                          kyyu
                                          @rv1974 said:
                                          Hi Kyyu!
                                          Thank you!
                                          You really want a one way ruby? copy/paste into ruby console or .rb file.
                                          UI.menu("Plugins").add_item("simple scale handles"){Sketchup.active_model.definitions.each{|e|e.behavior.no_scale_mask=88}}
                                          • K Offline
                                            kyyu
                                            Updated to v1.2, see 1st post. The menu item has always processed the selection, if it exsit. Now the toolbar icons do this, too. But there is an option to change it back to only processing all. See the description. Also, I darkened the icons.
                                            • 1 / 3
