    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Shell chair - Hans Wegner
    40 Posts 12 Posters 2.4k Views 12 Watching
      Looks like it was used hard and then refinished. Nice, nice.
      • massimoM Offline
        massimo Moderator
        Thanks again Dave. πŸ˜„
        Another couple of shots. Added a roughness map to the varnish of the woods and increased a bit the % of the roughness in order to have a different finishing. πŸ˜„
          Bellisimo!
          Is this a coating applied in Thea?
          Any chance I can see the Scattering and Structure settings? And Coating if you used it?
          • massimoM Offline
            massimo Moderator
            Grazie Rich. πŸ˜„
            Yes the wood mats have a stacked coating layer. Here are the settings I've used. As roughness map on the coating layer I've used the specular map. Only for the plywood I've increased the % of the roughness of the coating to 40.
              Excellent work.
                Thanks Massimo, appreciate it πŸ‘
                • massimoM Offline
                  massimo Moderator
                  Thanks Dave and Rich you're welcome. πŸ˜„
                  The last image for this thread, I promise... πŸ˜† I gave them a home. πŸ˜„
                    Nice, I love the way you bang your head off the light each time you stand up πŸ‘
                      Very nice work. You almost make me want to learn to do photo-realistic renders.
                      • massimoM Offline
                        massimo Moderator
                        Glad for that Dave. πŸ˜„
                        Yeah Rich, it's a way to remember how much you spent for that chandelier... πŸ˜‰
                        • K Offline
                          KarinaGM
                          Ohh that floor! That door! Those woods!!!
                          πŸ‘ πŸ‘ Perfect render massimo
                          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                          -BenjamΓ­n Franklin.**
                            d12dozr
                            Excellent renders, Massimo πŸ€“
                            http://goo.gl/f7ooYh
                            • broomstickB Offline
                              broomstick
                              This is truly a great render... congratulations!!
                              • massimoM Offline
                                massimo Moderator
                                Thanks guys. πŸ˜„
                                • olisheaO Offline
                                  olishea
                                  fantastic work massimo, last image is just beautiful πŸ˜„
                                  oli
                                    Looks who's back!
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks Oli and welcome back! πŸ˜„
                                      • olisheaO Offline
                                        olishea
                                        sorry i've been busy on an epic scale. good to be home, and that "homely" render really was a lovely welcome! πŸ˜„
                                        oli
                                        • dermotcollD Offline
                                          dermotcoll
                                          Brilliant, just brilliant. I am blown away by the quality of two renders tonight. This one is incredible. πŸ‘ πŸ‘ πŸ‘
                                          When you burn your arse - you gotta sit on the blisters!!
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks Dermot. πŸ˜„
                                            • 2 / 2
