    Shell chair - Hans Wegner
    40 Posts 12 Posters 3.6k Views 12 Watching
    • massimoM Offline
      massimo Moderator
      Thanks again Dave. πŸ˜„
      Another couple of shots. Added a roughness map to the varnish of the woods and increased a bit the % of the roughness in order to have a different finishing. πŸ˜„
        Bellisimo!
        Is this a coating applied in Thea?
        Any chance I can see the Scattering and Structure settings? And Coating if you used it?
        • massimoM Offline
          massimo Moderator
          Grazie Rich. πŸ˜„
          Yes the wood mats have a stacked coating layer. Here are the settings I've used. As roughness map on the coating layer I've used the specular map. Only for the plywood I've increased the % of the roughness of the coating to 40.
            Excellent work.
              Thanks Massimo, appreciate it πŸ‘
              • massimoM Offline
                massimo Moderator
                Thanks Dave and Rich you're welcome. πŸ˜„
                The last image for this thread, I promise... πŸ˜† I gave them a home. πŸ˜„
                  Nice, I love the way you bang your head off the light each time you stand up πŸ‘
                    Very nice work. You almost make me want to learn to do photo-realistic renders.
                    • massimoM Offline
                      massimo Moderator
                      Glad for that Dave. πŸ˜„
                      Yeah Rich, it's a way to remember how much you spent for that chandelier... πŸ˜‰
                        KarinaGM
                        Ohh that floor! That door! Those woods!!!
                        πŸ‘ πŸ‘ Perfect render massimo
                        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                        -BenjamΓ­n Franklin.**
                          d12dozr
                          Excellent renders, Massimo πŸ€“
                          http://goo.gl/f7ooYh
                          • broomstickB Offline
                            broomstick
                            This is truly a great render... congratulations!!
                            • massimoM Offline
                              massimo Moderator
                              Thanks guys. πŸ˜„
                              • olisheaO Offline
                                olishea
                                fantastic work massimo, last image is just beautiful πŸ˜„
                                oli
                                  Looks who's back!
                                  • massimoM Offline
                                    massimo Moderator
                                    Thanks Oli and welcome back! πŸ˜„
                                    • olisheaO Offline
                                      olishea
                                      sorry i've been busy on an epic scale. good to be home, and that "homely" render really was a lovely welcome! πŸ˜„
                                      oli
                                      • dermotcollD Offline
                                        dermotcoll
                                        Brilliant, just brilliant. I am blown away by the quality of two renders tonight. This one is incredible. πŸ‘ πŸ‘ πŸ‘
                                        When you burn your arse - you gotta sit on the blisters!!
                                        • massimoM Offline
                                          massimo Moderator
                                          Thanks Dermot. πŸ˜„
                                          • 2 / 2
