    Cant save my work
    7 Posts 4 Posters 565 Views 4 Watching
    • E
      ECOHOMES
      I know I was told to stay away from the forum - not ask so many questions - but after 3 days of utter frustrations I have no alternative left. My work will not save - the moment I want to save a model or save as I go along, the program seems to loop or something - I go to cntrl alt del and it tells me that the s-up program is not responding. I'm not a computer wizz... some of the work is saved as automatic saved - when I call this up and want to save it under a name I will recognize it simply closes the program.
      I have debugged the computer over and over, I have discarded Sk up and redownloaded and installed - same scenario.
      All my other programs work fine - save properly etc etc... only S-up...
      can anyone help please?
      Thank you.
      Hans
        Who told you stay away?
        Here's everything about saving....
        Save*
        Use the Save menu item to save the currently active SketchUp model to your file system. When you close an unsaved document, or attempt to quit SketchUp with unsaved open documents, SketchUp will prompt you to save your work before continuing.
        Keyboard Shortcut: Ctrl+S
        Tip: If Create Backup is enabled within the General panel of the preferences dialog box, the existing file will be converted to a backup file (.skb), and the new drawing will be saved in place of that currently existing file (.skp). The Create Backup option can help preserve your data in the event of an accidental removal of a .skp file. Backup files are saved in the My Documents (Microsoft Windows) or Library/Application Support/Google Sketchup 6/SketchUp/Autosave (Mac OS X) folder, by default.
        Tip: It is good to save often. You can have SketchUp automatically save for you at a specific time increment by enabling the Auto-save option within the General panel of the Preferences dialog box.
        Save As*
        Use the Save As menu item to open the Save As dialog box which defaults to the current document's folder. You can use this dialog box to save the current drawing as a new document. This file can be assigned a new name, a new location, and a previous version of SketchUp. The new file will become the current file in the drawing window.
        Save A Copy As*
        Use the Save A Copy As menu item to save a new file based on your current model. This menu item does not overwrite or close the current file and is useful for saving incremental copies or tentative schemes of your work.
        Save As Template
        Use the Save As Template menu item to save the current SketchUp file as a template. This menu item launches a dialog box where you can name the template and set the template as the default template (to be loaded every time you launch SketchUp).
        Are you doing this correctly?
        • honoluludesktopH
          honoluludesktop
          Hans, While probably unrelated to your problem, why don't you upgrade to Free SketchUp v8?
          • Jean LemireJ
            Jean Lemire
            Hi ECOHOMES, hi folks.
            How big is your file ?
            A large file, and I mean large (over 20 Megs), will take some time to save.
            If your file is less than 10 Megs, try using the Share File function to upload it to the 3D Warehouse (3DWH).
            If your file is too large for the 3DWH, try purging it of unused stuff like textures and components.
            As suggested, you can install SU 8 free in parallel with SU 6 without any problem. At one time on my PC, I had 5, 6, 7 and 8 and on my Mac, 6, 7 and 8.
            Just ideas.
            Jean
            • E
              ECOHOMES
              Hi, thank you for the interets - I did so some time back.
              Hans
              • E
                ECOHOMES
                ... I received a courteous email telling me to read the help section and with the 5% of questions i can not answer I should bring those to the forum... I have been around a while and can read betyween the lines - I was asking questions every day - this was obviously not on!
                Save*
                Save As*
                Save A Copy As*
                Save As Template
                Hi Rich,
                Yes I have been through all of that - as I said, in my frustration at loosing my work continuously, I even uninstalled and re downloaded again -
                I fully understand the concept of saving - I do a fair amount of video editing in pinnacle pro and also some graphic work in Coreldraw.
                I also teach Forex Trading technical analysis internationally via my computer so, yes I think that I truly tried all. My reason in coming to the forum was to see if this was possibly some known problem in the program.
                Thank you for replying,
                Regards
                Hans
                  Can you upload a .skp of the problem file? I think if it's below 4mb the forum will allow you to upload. Then we can test it to see if it's a corrupt file or that your PC is whacked.
