    [Plugin] RevCloud v1.1
    12 Posts 9 Posters 15.4k Views 9 Watching
    • TIGT Online
      (c) TIG 2011
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided that the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      RevCloud.rb
      Type 'revcloud' in the Ruby Console
      or choose 'RevCloud' off the Draw Menu [or shortcut to it].
      It draws a Revision Cloud.
      Pick a start-point, then hold down the left mouse-button to continue
      drawing the revcloud - you release the mouse-button to end it.
      It is represented by an orange arced-polyline until it is completed.
      The cloud is made 'flat', Z ia determined from the first picked point.
      You can (pre)set the 'segment-length' in the VCB; the default is 300mm.
      Each segments arc-radius should be approx. half of this.
      If you move the mouse very quickly the segment length may be larger.
      Move to within the 'segment-length' of the 1st point & release the
      button to make a closed loop, the VCB tells you if a 'closed loop' is
      possible.
      The last segment is then sized to close the remaining 'gap'
      Releasing the button before a 'closed loop' is possible makes a broken
      loop of the revcloud.
      You can then start a new revcloud after releasing the mouse-button.
      To exit the Tool select any new tool or Esc+Esc or press <Enter>.
      Esc undoes the current revcloud (if any).
      Normal Inference Tips may apply.
      Draw counterclockwise for outwards 'clouds' arcs & clockwise to make
      'spikes'...
      The revcloud is made in a group called 'RevCloud#1' - with an
      incrementing suffix.
      Version:
      1.0 20110622 First Issue.
      1.1 20110727 Draw Menu 'RevCloud' added.
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
        Well, isn't that slick! That's a great tool for those who need to make those sorts of clouds. Thanks, TIG.
          Ben Ritter
          TIG, thank you for all you've done to improve our workflow.
            bjornkn
            I had to look up what revision clouds are, and found this:
            Better be careful with them 😉
            It is impressive how you create new plugins all the time! Looks like it is just to whisper a wish and within a couple of hours it's ready 😉
            Great 😄
            • utilerU Offline
              utiler
              Great work, TIG!! I've wanted something like this for Layout but I don't believe we can write ruby for LO.... is that right?
              Just Curious...
              • P Offline
                prismcnd
                Thanks TIG, you are the best
                “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                • halroachH Offline
                  halroach
                  nice!
                  How can I assign a shortcut for revcloud to work?
                  FlexTools - Super Quick Windows, Doors, Slats...
                  • TIGT Online
                    Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=337237#p337237
                    It now has a 'Draw' menu item 'RevCloud'.
                    This can now be shortcutted.
                      boilingsnow
                      Thanks for this TIG!
                      How about the idea: converting existing lines or curves to RevCloud?
                      • TIGT Online
                        You can of course select the lines, add the RevCloud using the selection's vertices as snap points and then press delete to erase the selected lines...
                          millerjx
                          Can this be used/ adapted for Layout. Layout is where we really need to use it. Thank you
                          • TIGT Online
                            Why not make a few assorted RevClouds in a SKP.
                            White background, plan view etc
                            Make a new empty Layout file and add them to it [copy+paste].
                            Explode them [into images].
                            Then save those into a custom Scrapbook [named RevClouds?] and use that in any Layout file as needed - resizing/scaling them etc as desired...
                            They'll have a transparent ground and overlay if brought to front etc - layer than as desired too...
                            Of course you could make your own. entirely within Layout...
