    How do I change the size of a texture in Kerky?
    extensions
    3 Posts 2 Posters 498 Views 2 Watching
    • ToboboT
      Tobobo
      I use VRay at work and I can't afford VRay at home yet so Kerky is my next stop.
      However I can't seem to find how to change the size of a texture in Kerky and a search of the forum hasn't revealed anything.
      Please help a complete idiot (coz i'm sure its something very simple)
      Toby
      Philippians 4:13
      • ToboboT
        Tobobo
        Well, I knew it would be too simple!! 😳 😳 😳
        Toby
        Philippians 4:13
        • massimoM
          massimo Moderator
          In the first way you can change all the maps applied to an object at once (diffuse, bump etc) while in the second you can change them one by one.
          Remember that the number you see shows the times the texture is repeated on a surface, so higher the number smaller the texture.
