    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 128.0k Views 49 Watching
    • Q Offline
      qpik
      First of all thank you for the plugin.
      Have I just found a possible bug in kmlimport.rb, linestring method, line 422 - "<tesselated>" instead of "<tessellate>"?
      I'm learning how to model a terrain using my mobile's GPS and Sketchup. Since the Symbian app I use (GPSmap, http://www.vikinggames.hu/product.php?id=7) logs only CSV/KML Waypoints and additionally uses commas instead of points, so I have to manually convert the values. I'm new to KML (and I'm not a programmer) so the easiest way I noticed so far was to just put all the coords into a <LineString> tag, but in Sketchup the altitudes are wrong (i.e. flat or clamped to GE terrain).
      So I just go through your code and KML documentation to find a solution.
      Edit: which is as simple as adding <altitudeMode>absolute</altitudeMode> inside <LineString> tag.
        Aerilius
        That looks indeed like a bug! Thanks for reporting!
        • SygskyS Offline
          Sygsky
          Hi! I'm interesting in follow - how this scripts should/could work at all?
          I installed it correctly (think so), restarted SketchUp, called menu of "KML Tools", pointed "Export KML file" item, spend some time to look at the modal dialog, at last clicked "Ok" button, created new export file name and what? Nothing occurs! No any file anywhere was created, no any messages typed, nothing. Module keeps silence 😮)
          I have last version of free license SketchUp downloaded yesterday.
          Thx in advance.
            Do you have permission to write files to the destination folder ?
            Try your Desktop...
            Is there any exportable geometry in the SKP you are trying to export... etc ?
            • SygskyS Offline
              Sygsky
              Try your Desktop...
              Yes, yes, yes and yes all times 😎 But suddenly I found the solve. Don't sure what was an origin for the problem, so only describe result:
              Rubi is not one of my multiple languages but throw the code I found that in some checks if any external/internal functions in module return nil, it exits without warnings. As last action I did is a file name pointing, I tried to set full file path manually in the input dialog field, e.g. "C:\Temp\1.kml", not only name as it show in system dialog itself ("1.kml"). And it worked! So as I can suppose, alone file name is used internally to be used with some standard prefix of directory different from one used in a real path, use din dialog.
              Why? Windows 64b 7 Professional and Rubi pair knows only/ So export problems is solved. Let me check import ones in next time 😮)
              Thx for the wishes to help for this small problem!
              • K Offline
                KentD
                Hi Aerilius
                I´ve used your plugin now and it seems to really work.
                I have to export a whole modeled city and I want them to be separate models.
                Your plugin does the trick! I make components of every and each model an export them.
                BUT if I have to ROTATE any of my models they will be exported randomly(it seems) and NOT in their right position.
                Any good suggestion how to deal with this?
                Regards
                KentD
                  Aerilius
                  The plugin should consider the rotation of the group's/component's bounding box.
                  If the group is rotated, the rotation will appear as a "heading" attribute in the KML file, while the Collada file contains the group's inner coordinate system. At least it should work that way. Can you send (pm) me a file where it doesn't work that way?
                    SBMattingly
                    When using this tool that I just downloaded, I get a small window first that says "Loading correct elevation data failed. Internet Explorer 8 (or higher) required." I have IE 8 and SU 8.
                    Ruby console says the following: "fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=37.355313&lng=-108.385784&username=demo&style=full&callback=returnJson
                    returned:
                    {"status":{"message":"the deaily limit of 30000 credits for demo has been exceeded. Please use an application specific account. Do not use the demo account for your application.","value":18}}
                    Please help. I would love for this plugin to work.
                    Stan
                    • H Offline
                      humbertoanastasia
                      Hi there! Thanks for the plugin.
                      I'm having an issue, though.
                      I try to export an object, the dialog box opens, everything ok, and then...
                      Sketchup and the plugin just stop working.
                      Any ideas??
                      Tanhks!
                        Aerilius
                        What happens? What does "stop working" do?
                        And it's good if you tell me the file size, as described anything larger than some hundred kilobytes will take long. There is no simple way to make it faster.
                        • H Offline
                          humbertoanastasia
                          Thanks for the reply.
                          In fact, after I read your post, I tried "cleaning" the file, and minimizing it to the sole part of the model i wish to export. And... It worked out fine!
                          Thanks, and congratulations on your job!
                          • coda13C Offline
                            coda13
                            thank you very much!
                              Aerilius
                              **@thomthom said:
                              You're using a webdialog for the import - you can use the XML parsing capabilities of the web-browser:
                              http://www.w3schools.com/xml/xml_parser.asp
                              I'm working on a solution with a DOM xml parser.
                              It's more than 5 times faster than REXML (and probably much more in newer browsers). 😍
                                Aerilius
                                A quick update for compatibility with SketchUp 2013. It was released so quickly.
                                This is the last version before 2.0
                                  Aerilius
                                  I have uploaded a beta version of KML Tools 2.0!
                                  If you like, please help testing and give me feedback if files don't work with it.
                                  The new version has
                                  • significant speed improvements, up to 7× faster import
                                  • a reliable xml parser and better support for nested kml structures
                                  • better error handling
                                  • K Offline
                                    kubark42
                                    Just tried the beta, but it made no file output, just an empty directory. 1.4 works fine for me with the same workflow, so I'm either doing something wrong or it's not working on my model.
                                    EDIT: Sorry, I should have included some info. This is OSX 10.8 running SU8. Model can be downloaded from https://www.dropbox.com/s/q5a1hzqvcwlc39u/Geo-fence.skp
                                    • K Offline
                                      kubark42
                                      So this tool is really awesome, and almost exactly what I need. Thanks a million!
                                      Time for a tiny bug report: when setting the altitude mode to absolute altitude, instead of adjusting the Z values to the true altitudes, the script just sets the altitudeMode field to "absolute". The result is that a model that was drawn on the surface is buried in the ground in Google Earth.
                                        Aerilius
                                        Thanks for the feedback! I'll check your file and fix it.
                                        • K Offline
                                          kubark42
                                          Okay, figured out the second bug, and why I wasn't seeing it before:
                                              if facecolor
                                                @out.puts "  <Style>"
                                                @out.puts "    <LineStyle>"
                                                @out.puts "      <color>#{linecolor}</color>"
                                                @out.puts "      <colorMode>normal</colorMode>"
                                                @out.puts "      <width>1</width>"
                                                @out.puts "    </LineStyle>"
                                                @out.puts "    <PolyStyle>"
                                                @out.puts "      <color>#{facecolor}</color>"
                                                @out.puts "      <fill>1</fill>"
                                                @out.puts "      <outline>1</outline>"
                                                @out.puts "    </PolyStyle>"
                                                @out.puts "  </Style>"
                                                @out.puts "  <MultiGeometry>"
                                          only places the <MultiGeometry> tag if there is a facecolor. So moving " @out.puts " <MultiGeometry>"
                                          " to right after the "end" solves the problem.
                                          • K Offline
                                            kubark42
                                            Hi, Aerilius--
                                            I found out why I was having altitude problems. I don't program in ruby, but it looks close enough to other languages iI do program that I was able to muddle through it and realize that Altitude is not an attribute in GeoReference, so get_attribute("GeoReference","Altitude") returns 0. By changing Altitude to ZValueCentered, I was able to get a negative value in inches that is seemingly correct for my elevation. I cannot find a definitive reference on this, and there is also ModelTranslationZ which has the identical value for me, so I'm unclear which is the appropriate way forward. However, both solve my problem. So in conclusion, I've replaced line 253 by @ground = -@model.get_attribute("GeoReference","ZValueCentered").to_f.to_m and that solved my problem.
                                            Now I'm struggling with an odd error. For some reason when exporting a group to multigeometry the KML is missing the opening <MultiGeometry> tag, but it has the closing one. This causes an import error in KML until I manually add the XML tag.
                                            EDIT: terrain_alt([0,0,0]).to_m doesn't seem to return any sensible values. I'm interested if you have an idea about this, too.
                                            • 6
                                            • 7
                                            • 6 / 7
